05-04-2003, 11:50 PM
#1
98 Dakota Leaf Springs, work or no?
I called my local junkyard and they said that they have some 98 Dakota Leaf Springs that are 2.5 inches wide, these will work right?? To lift the jeeps saggin rear end. Hopefully some of you know what im talking about.
91 Jeep Cherokee Laredo
Flowmaster 50 series
ProComp 3" suspension lift
JKS Gen. II Quick Disconnects
31x10.5 Procomp M/T tires
15x8 Ultra 164 wheels
K&N Intake
CB
Stereo:
Panasonic CQ-DF601U headunit
Infinity 552i 5.25" coaxial speakers
Boston Competitor 10" subwoofer
JL Audio 250.1 amplifier
05-05-2003, 12:24 AM
#2
any leaf that is 2.5 inches wide and from a spring under axle pack will work to give you lift, just keep the main leaf and mix-n-match yours and dakota leaves till you get the lift you want.
Dacaur
99 WJ Laredo
2.5" Budget boost, 265/75/16 tires, K&N air filter
www.dacaur.com/jeep.html
Past Jeeps:
1992 YJ 4.0, 5 speed 6", lift 33's
1992 XJ 4.0, auto, 3" lift, 31's
1999 XJ 4.0, auto, 3" lift, 31's
1985 XJ 2.5, 5 speed, no lift, 255/70/15's
05-05-2003, 03:32 AM
#3
How much do you think it would lift just by swapping one set for the others? Even if it didn't lift it much, it would be nice to avoid the normal sag.
05-05-2003, 09:54 AM
#4
i have a question, you you think the factory soa springs are re-enforced against axle wrap any how?
i was wondering this cause the sua springs wouldn't have that
05-05-2003, 10:59 AM
#5
don't see any posts where someone thought they were reinforced
SOA you can use blocks for a cheap lift but they can cause axle wrap to the pivot point
SUA you can't use blocks unless you wanna lower it, so in that respect there is less axle wrap
05-05-2003, 01:07 PM
#6
i was just wondering cause they make re-enforced springs for yjs when you soa them i was just wondering.
thanks man
05-05-2003, 08:41 PM
#7
ive heard that the leaf under dakota springs give about 3" of lift, correct me if im wrong though...
[B]AMCrazy[/B].89 Xj, 2 door, 4.0, select-trac, aw4 tranny with manual shift switches and torque converter lock up, 6" of lift, 32x11.5 bfg mudders, on board air, tj flares, SYE, pre runner front bumper, rock sliders, roof rack, axle truss' hella and eagle eye lights, truck bed liner paint job, rci seats and harness' cobra cb, K&N cone, m.o.r.e. motor mounts, etc...
05-07-2003, 09:16 AM
#8
Heads up on Dakota springs
I just got off the phone with John at Standard Spring of Minneapolis Mn, He gave me the low down on the Dakota springs. You can use the leaves from the Dakota pack but not the main leaf. Xj springs measure 23 in front of the locator and 28 5/8 in the rear, Dakota springs measure 24 in front and 32 in the rear, Thus they definately will not work just to swap in. Now as far as the rest of the leaves the Dakota has a reinforced leaf in it to help carry heavy loads(also known as an over loads). It is my understanding this is where the harsh ride comes from when using Dakota leaves. I was just searching my options because my Xj is sagging in the rear with 3" of lift.  So I guess I will probably look for a leaf spring pack to solve this problem. So my question is who sells a good leaf pack set for 3-3.5" of lift. Hopefully this will help others thinking about this swap. Thanks Sonny
Life is short, wheel hard, sleep later
'97 Xj GOV'T issue with 4" lift 31" bfgs" 4.0,auto,242, 4.11 posi rear and to many ideas to list
05-07-2003, 03:34 PM
#9
Use Chevy S10 springs. Take your XJ main spring and add the center leaves from the S10. This will give you the 3" you want plus it will ride a lot softer than the Dakotas.
95 XJ Locked but stock (More mods to come)
57 Willys PU (The parade float)
87 Samauri (The Japaneese Jeep)
05-07-2003, 10:43 PM
#10
Which s10 should I look for a 2wd or 4wd. Alsowhat years like 95 up or pre 95. Thanks Sonny
05-07-2003, 10:55 PM
#11
Senior Web Wheeler
if I remember my s10s correctly they were all sua and had the same packs....
... an no sidewindin' bushwackin', hornswagglin' cracker croaker is gonna rouin me bishen cutter.
00 TJ
98 XJ
