98 Cherokee Sport Won't start - JeepForum.com
post #1 of 15 Old 03-07-2012, 08:30 PM Thread Starter
bossgator
I've wrestled with this for a while. Son's Cherokee won't start, we thought it was the starter, but it starts when we use the screwdriver trick on the solenoid. We next thought it might be the NSS, took it off and cleaned it, put it back on, no joy. Battery is good, continuity checks are good on the battery cables. When you turn the key you hear a click, not like a dead battery click, more like a relay is trying to engage, sounds like it is coming from passenger side under the dash or around the firewall. Any suggestions?
bossgator is offline
post #2 of 15 Old 03-08-2012, 12:10 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Only starts when you jump the starter solenoid ?
Clicking and not starting is usually a low voltage issue from:
  • leaving the lights on (or a short circuit)
  • a failing battery
  • a failing alternator
  • dirty or loose wire connections
  • internally corroded wires
Perform routine maintenance of the start and charge systems. Remove, clean, and firmly reconnect all the wires and cables to the battery, starter, and alternator. Look for corroded or damaged cables or connectors and replace as needed. Do the same for the grounding wires from the starter to engine block, and from the battery and engine to the Jeep's frame/body. You must remove, scrape, and clean until shiny, the cable/wire ends, and whatever they bolt to. Jeeps do not tolerate low voltage, bad connections, or poor grounds.
Have the battery, starter, and the alternator Load Tested for proper function in a machine that applies a simulated work load. Handheld testers are often inaccurate and will pass faulty parts.
CJ7-Tim is offline
post #3 of 15 Old 03-09-2012, 09:27 AM Thread Starter
bossgator
Its not really a clicking, like I have a low voltage situation. Battery test good, wires from battery to starter are good. When you turn the key, there is a sound like a relay kicking in (electrical sound) not full on clicking like a dead battery sound. We took the NSS out, cleaned and replaced, won't start in neutral, even after cleaning and replacing NSS. How do I test to see if the ignition switch is bad, before I go easter egging anymore?
post #4 of 15 Old 03-09-2012, 09:35 AM
CJ7-Tim
CJ7-Tim's Avatar
There are lots of JF members glad to help, but you need to provide some additional input.
Have you located the source of the click ? Have you inspected all the fuses and relays for failure or corroded contacts ? Why do you think the ignition switch is the cause ? Did you inspect all the wires and clean all the wire connections ? Did you have the battery Load Tested and the starter bench tested ?
CJ7-Tim is offline
post #5 of 15 Old 03-13-2012, 02:23 PM Thread Starter
bossgator
Well I finally got this old Jeep fixed! I went back and started at square one, bench test the battery and starter, both checked good. Went back and looked at the power distribution center and noticed I had a cracked starter relay, that still didn't do the trick. I had check and rechecked every connection we could find. We had cleaned up the NSS earlier, still nothing. So the only thing I had left was the ignition switch. Replaced that, still nothing! I put all the panels and plastic collar on the steering wheel back together and prepared to come back and ask more questions of the forum. My Son jumps in a starts the dang Jeep! He's screaming it works!, it works! So my question now is, is there some sort of safety switch incorporated into the steering column collar or something. Why did it suddenly work once the collar was back together?
post #6 of 15 Old 03-13-2012, 03:33 PM
CJ7-Tim
CJ7-Tim's Avatar
No secret safety switches. Most likely a dirty or corroded wire connection.
There was an optional chip-in-key security system, and they can get funky and act up.
CJ7-Tim is offline
post #7 of 15 Old 03-15-2012, 01:17 PM Thread Starter
bossgator
Or just FM!
post #8 of 15 Old 09-04-2012, 07:12 PM
Showtime3492
I hate to revive an old thread but im having some of these exact issues. My scenario is, 2000 xj just put a new engine in it (4.6 stroker) The engine will not start from the key, there are no reverse lights ( i know that points to NSS but bear with me) It will shut off from the key however, the key will pull out of the ignition when in the on position and running, when trying to start it with the key from inside the jeep there is nothing from the starter, no clicks nothing, the only noise when turning the key is a sound of a relay clicking on the lower passenger block. Gauges work fine (battery,oil pressure,rpm, etc) I thought if a NSS went bad the engine would still crank or click from the starter. I dont think that i missed any grounds but i may be wrong.
--1998 XJ "Mater"- RIP
2000 XJ--- 4.6 stroker. Saved from the grave- everything swapped or modded. I hate this thing :)
Showtime3492 is offline
post #9 of 15 Old 09-05-2012, 05:14 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
No. If the NSS is bad, no juice goes to the starter so you will have no crank and no click.
Because of that and because your reverse lights don't work, I'd suspect the NSS is a primary suspect here.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #10 of 15 Old 09-05-2012, 11:01 AM
graysonh
you can test to see if it is the NSS without even taking it off, search on this forum how to bypass the NSS and see if that works for you
graysonh is offline
post #11 of 15 Old 09-05-2012, 11:44 AM
tjwalker
tjwalker's Avatar
Here is a link to an article on "refurbishing" and also bypassing the neutral safety switch. Bypassing is recommended for testing only as the NSS does have a number of useful purposes.
http://go.jeep-xj.info/HowtoNSSrebuild.htm
tjwalker is offline
post #12 of 15 Old 09-06-2012, 03:07 PM
Showtime3492
Thanks guys! plugged a "new" to me NSS in and got it to start with the key but in neutral. Also still have a tranny code. Gonna unplug it again and dissasemble and clean.
post #13 of 15 Old 12-20-2014, 02:38 PM
99jeepc
99 Cherokee has new fuel pump smell fuel replaced the crank sensor again it went bad 6 months ago turns over wont start
99jeepc is offline
post #14 of 15 Old 12-20-2014, 04:25 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
alittlebitofpunctuationeffortgoesalongways
***Chris***
chris87xj is offline
post #15 of 15 Old 12-20-2014, 05:26 PM
tjwalker
tjwalker's Avatar
Along with starting a new thread. This thread is from 2012.
This is a new problem and starting a new thread is the most efficient way to get the most accurate replies!
tjwalker is offline
96 Cherokee Sport Won't Start Physiksgeek XJ Cherokee Technical Forum 3 03-05-2011 07:54 AM
99 Cherokee Sport Will not start- HELP! shanerf XJ Cherokee Technical Forum 5 05-25-2010 05:45 AM
94 Cherokee Sport New for me where to start? brahm XJ Cherokee Technical Forum 11 12-08-2008 06:10 PM
98 Cherokee Sport won't start... Cheeba XJ Cherokee Technical Forum 3 11-20-2006 10:26 PM
94 Cherokee Sport won't start rustedrootbeer XJ Cherokee Technical Forum 6 09-02-2005 01:36 PM
