98 Cherokee sport gas milage - JeepForum.com
post #1 of 7 Old 06-11-2013, 05:23 AM Thread Starter
Mattsy
Good morning all, My 98 Cherokee is only getting around 180 miles to a tank of gas. Does anyone know of a computer chip that would shut down a couple fuel injectors, so that it would be a four cylinder when needed and I can turn a knob or push a button to switch it back to 6 cylinder as I need more power?
Thanks. Mattsy
Mattsy is offline
post #2 of 7 Old 06-11-2013, 04:05 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Moved to Cherokee Forum.
Wheelin98TJ is offline
post #3 of 7 Old 06-11-2013, 04:28 PM
mschi772
1997 XJ Cherokee
Even if you could do that, which you can't as far as I know, you wouldn't really save much if any gas because the other four cylinders would have to work that much harder to move the dead weight cylinders. Heck even the REAL 4-cyl engines that literally are the same as the 4.0 minus two cylinders don't get much better mileage than the 4.0. There are a million threads on XJ and/or 4.0 mileage. There's no magic bullet, but look those threads up to learn what you CAN do.
Build Thread -- http://www.jeepforum.com/forum/f177/whats-chrokeese-build-thread-2525690/
mschi772 is offline
post #4 of 7 Old 06-11-2013, 05:03 PM
sluff28
1975 CJ5
my 01 only gets 210 miles per tank on a good day 180 on a normal day what are your modifications everything you do will cut into your mileage.
sluff28 is offline
post #5 of 7 Old 06-11-2013, 05:17 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Miles per tank has no meaning at all, sort of like ants per picnic. The gas gauge is not calibrated, and the readout is not linear, it is just a more or less indicator.
Calculate your actual Miles Per Gallon, and then use the Google to compare your results to other XJ owners with similar modifications. If necessary, adjust your MPG figures for non-stock size tires and/or gears.
To increase your MPG's, do all the normal stuff, tune-up, make sure your tires are properly inflated, and perform any necessary maintenance/replacement required to the catalytic converter, O2 sensors, and other engine sensors.
CJ7-Tim is offline
post #6 of 7 Old 06-11-2013, 09:55 PM
ECL
Tank size is about 18 gallons if i recall correctly. Getting 180 miles on about 18 gallons is only about 10 mpg. Something sounds out of whack. Time to think about a tune up, O2 sensor, etc or take it easier on the gas pedal.
For reference, my 98 4.0 w/ 5 spd gets high teens routinely back and forth to work. I'Ve gotten low 20's on the highway. My daughter got 25 coming home from college once on some good southern summer blend gas (I'm convinced regional and seasonal differences in gas blends can have a big effect on mileage).
ECL is offline
post #7 of 7 Old 06-11-2013, 11:37 PM
sAe23
1995 XJ Cherokee
I get about 240 ants per picnic...
sAe23 is offline
