'98 Cherokee Serp Belt Help - JeepForum.com
post #1 of 5 Old 06-21-2011, 06:39 AM Thread Starter
naiou12day
1998 FSJ Cherokee
Hey gang-
I have a '98 4.0l L6 Cherokee that is having AC issues. Bought a new Serp belt from Advance Auto yesterday that is "Supposed" to be able to completely circumvent routing around the AC compressor, but I am unsure what the Routing diagram would look like. If anyone has done this, or has a diagram for "Skipping" the A/C alltogether, I would appreciate it!
naiou12day is offline
post #2 of 5 Old 06-21-2011, 07:28 AM
kadetklapp
1997 XJ Cherokee
I'm looking around on the net for a diagram for you, but just to be sure, there should be a diagram under the hood. It will show a dotted line for "No AC" on the diagram. If it's not there report back.
**Edit, here you go**
**1997 Jeep Cherokee SE**
Former Police Car assigned to 54-26, RIP.
kadetklapp is offline
post #3 of 5 Old 06-21-2011, 07:40 AM
AZ Jeff
2014 JK Wrangler
Originally Posted by naiou12day View Post
Hey gang-
There is NO SUCH THING as a "shorter" or "different" belt for a non-AC version of the 4.0 engine.
On engines without AC from the factory, and idler pulley was installed in place of the compressor, allowing the same belt to be used.
Despite what some may think or say, there is NO WAY to "reroute" the belt on the 4.0 to bypass the compressor and still have all pullies turning the correct direction.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #4 of 5 Old 06-21-2011, 07:49 AM
kadetklapp
1997 XJ Cherokee
So in the diagram above, is that showing the replacement pulley?
post #5 of 5 Old 06-21-2011, 08:29 AM
danw77
1994 ZJ
the diagram you posted is for a yj, not an xj.
here is the correct diagram. as mentioned, if there is no a/c, the compressor is replaced with a pulley and the belt routing remains the same. there is no way to use a shorter belt and bypass the a/c. if you want to remove the compressor, NAPA sells the bypass pulley: https://www.napaonline.com/Catalog/C...323731841&An=0
1983 CJ7 & 1998 ZJ
Hello, my name is Dan, and I have a Jeep problem.
danw77 is offline
help needed , serpentine belt
serp belt help rstampo XJ Cherokee Technical Forum 2 04-22-2011 07:29 PM
Anyone Know Serp Belt Number To Put On Without Ac On A 4.0 95 Cherokee 95CHERJUST XJ Cherokee Technical Forum 6 09-11-2008 05:52 PM
Stupid belt tricks? Serp belt recommendations please diskman_1 XJ Cherokee Technical Forum 7 07-03-2008 11:45 PM
88 Serp Belt Help cherokee88p XJ Cherokee Technical Forum 1 01-29-2005 06:08 PM
New Serp Belt??? ddoffroad XJ Cherokee Technical Forum 2 01-11-2003 09:54 AM
