98 Cherokee Runs terrible cold but good warm - JeepForum.com
post #1 of 2 Old 09-28-2011, 01:57 PM Thread Starter
officialvin
Hey. My cherokee runs terrible when i first start it up, it misses and sometimes stalls. it smells like its running very rich also. Once it warms up to 210 it runs pretty much perfect.. I had an issue with it randomly running bad while driving and idling and i replaced the upper o2 sensor and it was fine. about 2 days later this problem started. I have replaced the TPS IACV Air temp sensor in the intake.. Im thinking it may be the ECTS but my temp gauge works fine so im not sure.. also plugs wires cap and rotor are pretty new. Anyone have any ideas? thanks in advance
officialvin is offline
post #2 of 2 Old 09-28-2011, 02:05 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Have you put a scan tool or a code reader on to see if you have any stored codes?
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
runs great cold but when warm it runs bad. flaneryjunior99 XJ Cherokee Technical Forum 4 07-09-2011 05:29 PM
cold start good idle - engine gets warm and low idle ahuf XJ Cherokee Technical Forum 9 01-30-2011 03:17 PM
New member can use a little help. XJ runs warm? mula XJ Cherokee Technical Forum 19 12-12-2010 07:27 AM
AC cold 10 minutes, warm 20, cold 10... js5278 XJ Cherokee Technical Forum 9 06-18-2010 02:56 PM
Runs rough when warm, help Hendo_10 XJ Cherokee Technical Forum 4 01-03-2006 02:50 PM
