98 Cherokee P1698 Fault Code - JeepForum.com
post #1 of 6 Old 02-13-2012, 06:47 PM Thread Starter
jmadlem2
I have a 98 cherokee with a P1698 Fault Code. This issue came up after swapping the engine out. When the TCM is plugged in the Speed o meter doesnt work. But when it is unplugged it works properly. The trannsmission is stuck in high gear (over drive) at all times. I tried swapping out the tranny but this didnt correct the problem. Could anyone point me in the right direction before I spend anymore money on my project.
Thank You,
jmadlem2 is offline
post #2 of 6 Old 02-13-2012, 07:03 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
P1698 No CCD/J1850 Message From TCM electronic transmission control module (EATX) or the Aisin transmission controller.
Faulty TCM, faulty/damaged transmission sensors or speedometer sensor, or damaged wires.
Randomly swapping parts in the hopes accidentally fix a problem gets expensive in a big hurry. Do you have a Factory Service Manual ?
What year was the donor ? Were the flywheels the same ?
CJ7-Tim is offline
post #3 of 6 Old 02-21-2012, 01:51 AM Thread Starter
jmadlem2
The flywheel is the original one. What i did is rebuilt the motor myself. No I don't have the factory service manual. The transmission shifts strong manually. All conections from the tcm and ecm read fine. Ive also replaced the speed senor recently.
jmadlem2 is offline
post #4 of 6 Old 02-21-2012, 10:20 AM
CJ7-Tim
CJ7-Tim's Avatar
Shifting normally when shifted manually points more toward an electrical issue. Since you recently performed major repairs, the logical starting point is confirming everything is correctly installed, correctly connected, and that no wires or components were damaged during the work.
Consider a used TCM from the junkyard as they cannot be easily tested. Otherwise, test and inspect for faulty/damaged transmission sensors, speedometer sensor, Neutral Safety Switch (NSS), or damaged wires.
CJ7-Tim is offline
post #5 of 6 Old 02-21-2012, 07:50 PM Thread Starter
jmadlem2
This is what I figured an electical issue. I thought if the transmission shifted normally manually that it couldn't be mechanical. I will trouble shoot what I can. I willing to bet some wires got damaged during the engine installation. I'll let you know what I find. Thank you for the help.
jmadlem2 is offline
post #6 of 6 Old 03-12-2012, 07:01 PM Thread Starter
jmadlem2
Problem solved. The ground(blk/tan) wiring on TCM wasn't getting a strong enough connection. Thanks for the help.
jmadlem2 is offline
1998 , cherokee , p1698 , xj
95 Jeep Cherokee - I6 - Fault Code 24 steve_bk XJ Cherokee Technical Forum 4 08-24-2014 06:33 PM
P1698 code taz888 XJ Cherokee Technical Forum 2 02-27-2012 07:44 PM
P1698 code bobbyracer XJ Cherokee Technical Forum 1 12-12-2008 07:42 PM
trouble code P1698 no trans bus massage amircal XJ Cherokee Technical Forum 1 03-25-2006 06:13 AM
Engine light, the code was P1698 Help arieljeep XJ Cherokee Technical Forum 3 08-18-2005 06:07 AM
