'98 Cherokee Loss of Power and Stalling - JeepForum.com
post #1 of 5 Old 11-20-2013, 09:30 PM Thread Starter
koko2635
Ok I'll try to be as detailed as possible.
I have a 98 cherokee that I just replaced the thermostat and housing gasket on yesterday.
She ran fine all day yesterday and today up until I was driving home and I noticed there seemed to be a lack of power and response when I hit the gas. Later in the day I went to run some errands and when I hit the gas there was no response and she began to stall out every time I tried the gas. Eventually she just died all together and has troubles restarting.
It should also be noted that I need to replace my A/C Compressor which makes her squeal at me when I first start her.
What are some possible problems/solutions?
koko2635 is offline
post #2 of 5 Old 11-20-2013, 09:53 PM Thread Starter
koko2635
Most likely problem so far in my research is there is a leak somewhere thats causing to much air to come in. Any common connectors or hoses that like to crack or pop off?
koko2635 is offline
post #3 of 5 Old 11-21-2013, 11:24 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Start with the basics, does it have spark at the spark plugs, and are the fuel injectors firing ? Next, test the battery and the alternator. Inspect the battery wires, clean the ends, and bolt them back in place firmly. The Jeep will not run correctly without a steady supply of 12 volts to the computer. If you still have the problem, test the Throttle Position Sensor.
Tighten the fan belt, it should stop squealing.
Too much air coming in isn't is not a actual problem, unless you are talking about intake manifold leakage causing the engine to redline the tachometer.
CJ7-Tim is offline
post #4 of 5 Old 11-21-2013, 09:53 PM
Holder350
1995 XJ Cherokee
You should also check fuel pressure.
Also, I it's doubtful your AC compressor is faulty just because the belt squeals when its started. Most likely needs a decent quality belt (like Goodyear) on it at the proper tension. Most people who replace the belts on the 4.0 fail to realize how tight they actually need to be.
Sent from my phone where correct grammar is difficult.
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #5 of 5 Old 11-26-2013, 08:27 PM
kbad
hey Koko ... ditto all of the other suggestions .. however, you mentioned the squealing and since you replaced the thermo, my best personal experience suggestion would be that your water pump is shot or about to go ... it would be a good idea to check it out while you are at it or replace it altogether if you don't know its history - water pump impeller shards would be costly if they ended up inside your engine cooling parts! .. good luck!
kbad is offline
power , stalling , thermostat , throttle , xj
