98 Cherokee heat not working - JeepForum.com
post #1 of 10 Old 03-03-2009, 12:36 PM Thread Starter
Lupinus
Hi All,
I'm looking to buy a 98 Jeep Cherokee 4.0 2x4 with 147k on the clock.
All appears to be fine with the vehicle except for the heating.
The vehicle reached and maintained operating temperature with no issue ruling out the water pump or thermostat (please correct if I'm wrong). It also changed zones fine, so it blew out air where it was supposed to. The air also was not ice cold, but not warm either.
There was some light non-constant belt noise while warming up and for the first couple minutes of the drive. I haven't had a chance to inspect this yet and plan to do so later today when I take the vehicle for a once over at my mechanics shop. Right now I'm thinking it was just a wet belt due to the weather of the past couple days.
According to the seller he thinks it has something to do with the switch inside the dash that tells the car to blow hot air, and is dropping the price accordingly.
As I'm not familiar with this model does anyone have other ideas on what it could be?
Lupinus is offline
post #2 of 10 Old 03-03-2009, 01:03 PM
kzjim
I'd check the heater control valve, its vacuum operated, see if its opening up.. if it is.. the heater core might be plugged up.. check the radiator fluid, it rusty colored or clean?
If its not opening up, it could be the switch in the dash..
"Those who hammer their guns into plows will plow for those who do not"...Thomas Jefferson
"Beware lest the Stone Age return on the gleaming wings of science." - Winston Churchill
kzjim is offline
post #3 of 10 Old 03-03-2009, 01:23 PM Thread Starter
Lupinus
Probably a stupid question...whereabouts in that heater control valve?
Lupinus is offline
post #4 of 10 Old 03-03-2009, 01:44 PM
kzjim
It's on the passanger side of the engine compartment near the fire wall.. follow the two heater hoses along side the valve cover back it, they will lead you right to it...
kzjim is offline
post #5 of 10 Old 03-03-2009, 01:46 PM Thread Starter
Lupinus
Thanks for the help Kz.
Lupinus is offline
post #6 of 10 Old 03-03-2009, 02:40 PM
Mikes99XJ
I know that the 99 doesnt have one, and I'd venture to say that anything later than 99 doesnt have it either but IDK. I have been having the same issue, but I've tracked it down for some time now. First it was said that it could have been the blend door motor or shaft for the blend door itself. Well i checked all that and it ends up that I found out the heater core has very small "capilary" tubes inside the bigger heater core. It will still flush as normal, but flushing wont wash out these small capilary tubes. Basically, it comes down to replacing the heater core, which means the dash comes out.
Mikes99XJ is offline
post #7 of 10 Old 03-03-2009, 04:29 PM
AZ Jeff
2014 JK Wrangler
There is NO HEATER CONTROL VALVE on a 97+ XJ.
I am betting the heater core is plugged up on the OP's "target vehicle".
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #8 of 10 Old 03-03-2009, 06:21 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
X3; no heater control valve on a 98. I agree with Jeff.......a clogged heater core is awfully common, especially on vehicles that have not had routine cooling system maintenance. You always want to try flushing the heater core with "moderate" water pressure before giving it the last rights and tearing into the dash.
How much is he asking for the 98??
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #9 of 10 Old 03-03-2009, 06:53 PM
kzjim
thanks for the info on the 97+ az jeff... i have to agree that the heater core is suspect...
kzjim is offline
post #10 of 10 Old 03-04-2009, 04:28 AM Thread Starter
Lupinus
yep once we got the hood open it was the core based on the hoses.
I've got him down considerably from the original asking price; its in otherwise excellent shape except for the heat, a valve gasket, and needs the break cylinders replaced. Price is I'd say fair plus about 50-100 bucks, but I like the vehicle so what the heck.
Lupinus is offline
heat not working with new thermostat? fphipps XJ Cherokee Technical Forum 4 12-16-2010 12:09 PM
Heat not working mindless XJ Cherokee Technical Forum 6 01-20-2009 09:23 PM
ac/heat blower stoped working help its cold!! KrazyKarlXJ XJ Cherokee Technical Forum 1 12-11-2007 12:26 PM
G-DAMNED EFFING HEAT HAS TO STOP WORKING TODAY:mad: Meatroach XJ Cherokee Technical Forum 12 12-01-2006 11:03 PM
A/c and heat not working, fan not blowing Opi XJ Cherokee Technical Forum 3 08-21-2006 11:16 AM
