98 cherokee cranks but no start - JeepForum.com
post #1 of 4 Old 06-02-2012, 10:47 PM Thread Starter
desertwrench
I just put an engine and trans. in my friends cherokee. It cranks but doesn't start. Has spark and fuel at the fuel rail, but plugs are dry. I'm thinking the injectors aren't spraying. Any ideas? Rollover switch, or anything like that? Any ideas would be greatly appreciated. Thanks, Jason.
desertwrench is offline
post #2 of 4 Old 06-03-2012, 08:25 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Details required:
Vehicle year ?
Year of donor engine ?
Transmission ?
Year of donor transmission ?
Go back over the install, make sure everything is hooked up and hooked up correctly. The Crank Sensor and the Cam Sensor are the primary controls, are they correct, undamaged, and installed correctly ?
CJ7-Tim is offline
post #3 of 4 Old 06-03-2012, 08:34 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Did you actually pull a plug and verify that you have spark?
With the swapping of the engine and transmission, the first thing for you to check is that the crankshaft position sensor is plugged in.
Driver's side of the bellhousing.
Without that input signal, you won't have spark and you won't have fuel going to the fuel injectors.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #4 of 4 Old 06-03-2012, 08:40 AM
XJNKY
^What they said, but also, check the ASD circuit in the fuse/relay box under the hood. If I recall correctly, that will also prevent fuel delivery.
XJNKY is offline
cherokee , no start
1985 Cherokee cranks but won't start marckray XJ Cherokee Technical Forum 3 08-15-2011 10:15 AM
Cherokee cranks but won't start. gmerkle XJ Cherokee Technical Forum 15 09-10-2010 10:40 AM
99 My Cherokee's new engine cranks but won't start dabincharlotte XJ Cherokee Technical Forum 3 07-16-2009 01:40 PM
cherokee cranks over but wont start please help amazingman XJ Cherokee Technical Forum 7 03-31-2009 09:40 PM
cherokee cranks over but will not start help!!! amazingman XJ Cherokee Technical Forum 2 03-29-2009 06:42 PM
