98 cherokee 4.0: low oil pressure and check gauges light - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > 98 cherokee 4.0: low oil pressure and check gauges light
Poly Door Hinge BushingsStainless Steel Door Hinge PinsNew Knuckles Skid Plate at JeepHut
Unread 12-21-2008, 01:11 PM   #1
snopro442
we have a 98 cherokee limited with a 4.0 straight 6, when leaving it idle for a while, the oil prssure guage will drop to almost 0 and the check gauges light will come on, it runs fine and no engine noises. also when driving the jeep, the oil pressure gauge will go well above 40 psi and then at a stop sign it will drop well below 40 almost to 10-15 psi. we did install a new pressure switch a few months back(down by the distributor) we checked it and it is still plugged in tight and not broken off like the old one did, can someone please point us in the right direction as to what we should be looking for? thanks for your time and help, todd in wi.
snopro442 is offline   Reply With Quote
Unread 12-21-2008, 01:51 PM   #2
tjwalker
It's the crank sensor!
tjwalker's Avatar
The oil pressure sending unit (aka: switch in some parts stores) is located directly above the oil filter, not by the distributor. Still sounds like an oil pressure sending unit to me. You could verify with a mechanical gauge if you're ambitious but if it were me, I'd buy a replacement sender directly from Jeep for best reliability/mating/accuracy with your factory gauge.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is online now   Reply With Quote
Unread 12-21-2008, 04:55 PM   #3
snopro442
yes the unit by the filter, we checked into it somemore and found that the harness plugwas not tight onto the sending unit, the replacement unit was from auto zone so we used a few plastic zip ties and fixed it, thanks todd
