98 4.0 Cranks but no spark at coil - JeepForum.com
post #1 of 11 Old 11-04-2008, 02:12 PM Thread Starter
csfiend
98 XJ 4.0, auto.
I went out to my Jeep this morning to go to work and it'll crank and crank but not start. I have fuel pressure at the rail. I checked for spark and I have none, even at the coil. Pulled the coil out and found a crack in one of the corners, so I replaced it due to the crack and the lack of spark at the coil. Still have no spark at the coil. I swapped the ASD relay with a known good unit, no start. I haven't checked anything else as I needed to get to work.
What would be the next thing to check, and how would I check it? I used to be a technician for a few years, but I don't have access to any of the wiring schematics or diagnostic flowcharts that I normally would use so any help is appreciated.
Thanks!
csfiend is offline
post #2 of 11 Old 11-04-2008, 02:28 PM
johnsoninc86
Your CPS is bad. There is a way to test it. I think you have to test the resistance between pole 1 and 2, not sure though. Do a search and you should be able to come up with it, but that definately sounds like a CPS.
98 XJ Sport
07 JKU Sahara
johnsoninc86 is offline
post #3 of 11 Old 11-04-2008, 02:36 PM
Stormwalker
That's exactly what I told him when I gave him a ride to work!
Stormwalker is offline
post #4 of 11 Old 11-04-2008, 02:46 PM Thread Starter
csfiend
Hey, I wasn't doubting you one bit, but like I said earlier -- I need to be able to prove something is wrong before I'm comfortable replacing it.
csfiend is offline
post #5 of 11 Old 11-04-2008, 04:20 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Here's the procedure for testing the CPS on the Jeep 4.0......Good Luck!
CPS TESTING PROCEDURE 1991 – 2001 4.0L H.O. engines
1. Near the rear of intake manifold, disconnect sensor pigtail harness connector from main wiring harness.
2. Place an ohmmeter across terminals B and C (A-B-C looking into connector left to right with the part with the notch in the middle on the right) Ohmmeter should be set to 1K-to-1OK scale for this test.
3. The meter reading should be open (infinite resistance). Replace sensor if a low resistance is indicated.
CPS TESTING PROCECURE for 1987 – 1990 4.0 L engines
Test # 1
Get a volt/ohm meter and set it to read 0 - 500 ohms. Unplug the CPS and measure across the CPS connector's A & B leads. Your meter should show a CPS resistance of between 125 - 275 ohms. If the CPS is out of that range by much, replace it.
Test # 2
You'll need a helper for this one. Set the volt/ohm meter to read 0 - 5 AC volts or the closest AC Volts scale your meter has to this range. Measure across the CPS leads for voltage generated as your helper cranks the engine. (The engine can't fire up without the CPS connected but watch for moving parts just the same!) The meter should show .5 - .8 VAC when cranking. (That's between 1/2 and 1 volt AC.) If it's below .5vac, replace it.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #6 of 11 Old 11-04-2008, 08:30 PM
HighCountry
It is such a no brainer... IF you are serious about keeping the Jeep, you WILL need both a Crank Sensor and a Cam Sensor some time in the future. If you just buy them both and stash them below the back seat along with the tools it takes to change them, it will save you a Wrecker Charge some day.
I always recommend doing a quick Test change of the Cam Sensor before swapping the Crank Sensor since it takes a couple of minutes and only requires a Phillips Screwdriver.
Later, Bruce
HighCountry is offline
post #7 of 11 Old 11-05-2008, 01:52 PM Thread Starter
csfiend
Surprise, surprise -- new CPS sensor and it fired right up.
Regarding the above post, I don't remember the range of years but in 98 at least the cam sensor only controls fuel injector timing, NOT spark.
csfiend is offline
post #8 of 11 Old 11-05-2008, 08:25 PM
johnsoninc86
glad you got er fixed!
98 XJ Sport
07 JKU Sahara
post #9 of 11 Old 11-06-2008, 09:09 AM Thread Starter
csfiend
meeeee too
thanks for your help!
csfiend is offline
post #10 of 11 Old 04-18-2009, 02:34 PM
opusgamma
1988 XJ Cherokee
Hi guys sorry to highjack this thread..but i might be having the same problem and here in Dominican Republic are not that many Mechanic that know how to deal with XJ...
I just did an enginge change from a 88 4.0l to a 2002 4.0 ho I left its old fule rail and al lthe electric so i did not need ot do any electrical work but know it turn and i get no spark just like the Op.. can some one telll me what is the CPS and where is located pelase so can do the test sugest on top.
thank
Albin
opusgamma is offline
post #11 of 11 Old 04-18-2009, 02:36 PM
opusgamma
1988 XJ Cherokee
thank I found it... but had change it and it had less than 1000 miles... anything else?
http://autorepair.about.com/library/...s/bl860lib.htm
97 xj 4.0 Cranks No spark new cps nd4spd4axj XJ Cherokee Technical Forum 30 06-03-2014 10:33 AM
'93 4.0 Cranks, Fuel, No Spark at coil DiamondFanatic XJ Cherokee Technical Forum 14 12-10-2011 09:35 AM
4.0 cranks but no spark ZeroLag XJ Cherokee Technical Forum 6 08-24-2009 12:18 PM
92 4.0 no spark and no fuel, cranks ok tnsdl XJ Cherokee Technical Forum 3 04-29-2009 04:27 AM
cranks with fuel, no spark. What's 1st JB-Norcal XJ Cherokee Technical Forum 4 05-22-2008 10:41 AM
