97xj clunking while braking - JeepForum.com
post #1 of 9 Old 06-28-2013, 08:17 PM Thread Starter
Norton21
I have a 97 xj with 80,000 miles, yup, 80,000 miles! Recently when I apply the brakes driving the front end has been a clunking noise,the pads and rotors are brand new within the past 5 months. I took it all apart they all look fine. It only really happens when braking harder or braking from a higher speed. Any one have any ideas what it could be?
2'BDS/5100 SHOCKS/BFG-KO
Norton21 is offline
post #2 of 9 Old 06-28-2013, 08:36 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Suspension or steering, assuming there is no excessive wear or pits on the steering knuckle slide points for the calipers.
CJ7-Tim is offline
post #3 of 9 Old 06-28-2013, 08:42 PM Thread Starter
Norton21
Yeah I replaced the slides for the calipers I'm case it was that, what in the suspension do you think it could be, a bad bushing? It's only while braking though which is puzzling...
Norton21 is offline
post #4 of 9 Old 06-29-2013, 01:18 PM Thread Starter
Norton21
Anyone else have any suggestions?
Norton21 is offline
post #5 of 9 Old 06-29-2013, 07:19 PM
CJ7-Tim
CJ7-Tim's Avatar
So how did the inspection of steering and suspension go ? Checked torque on all the fasteners ?
CJ7-Tim is offline
post #6 of 9 Old 06-29-2013, 07:46 PM Thread Starter
Norton21
I checked the bushings today they all seem fine, I felt for play in the tie rods they were good too
Norton21 is offline
post #7 of 9 Old 08-11-2013, 12:31 AM Thread Starter
Norton21
late response, turned out to be a stripped bolt between the steering knuckle and caliper. I drilled it out re-tapped it and put in a hell coil, fixed the problem!
Norton21 is offline
post #8 of 9 Old 08-11-2013, 01:48 AM
Trainhop91
Was it only happening on one side? I've got the same problem on the front left side! Mind getting a picture of the bolt that was stripped?
Trainhop91 is offline
post #9 of 9 Old 08-11-2013, 12:26 PM Thread Starter
Norton21
Yup 1 side, it was the front drivers side. The caliper whole was stripped and there was play in the bolt. it took about 10 mins to fix and solved the problem sorry I dont have any pictures. Just take the wheel off and see if the bolt has any play from the steering knuckle to the caliper.
Norton21 is offline
