97 XJ Worth It? - JeepForum.com
post #1 of 6 Old 10-24-2013, 07:08 PM Thread Starter
Jimidude87
97 XJ Worth It?
Hey guys I am new to this part of the forum. I am used to posting in the YJ section but I am considering adding to my collection.
I found an ad for a 97 Cherokee that has a 4.0 with a 5 speed manual transmission and is 4x4. The guy is asking $750 for it. Here is why so cheap. The motor is no good and needs to be replaced or rebuilt. I feel like this could be perfect for me because during my yj project I bought a 4.0 motor and was thinking about swapping that in but ended up rebuilding the original motor. So I have a 4.0 motor sitting in my shop. The only thing im not sure of is the motor that I have came out of a 95 cherokee.
My question to you guys is this: will I have any problems dropping this motor into that cherokee with the cherokee being 2 years newer...will the wiring be the same? Also, does this sound like a good price for that package? Thanks for all of your help and hopefully I will be on this part of the forum a lot more in the near future.
Jimidude87 is offline
post #2 of 6 Old 10-24-2013, 10:06 PM
xjdantheman
1993 XJ Cherokee
If the spare motor you have is an obd2 one then its a straight swap, also hope it came out of an xj.
But if its obd1 then all you have to do is swap over some parts.
xjdantheman is offline
post #3 of 6 Old 10-25-2013, 07:53 AM
Azzy
If the body isnt rotten out, should be. What does a blown motor mean anyway? Lots of people say things are blown or bad because they have no idea how to fix them (or bother searching on here)
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #4 of 6 Old 10-25-2013, 08:31 AM
Battle
If it's a Florida Cherokee it should have zero rust. OBD II was US standard in 96 but some late year 95s were made OBD 2. I honestly have no clue if Jeep ever did this but I have reason to believe they did not and your 95 4.0 is OBD I which means the swap would not be as cut-and-dry as you might think.
99 XJ Sport - 4.0, AX15, NP231 (Current)
98 XJ Classic - 4.0, AW4, NP231 (Former)
Battle is offline
post #5 of 6 Old 10-25-2013, 11:13 AM Thread Starter
Jimidude87
I believe it is a florida jeep...im not sure if the motor that I have is obd I or II...if it is I than what would I have to do in order to make it work? is it a big PITA?
post #6 of 6 Old 10-25-2013, 11:30 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Any 1990-2001 XJ or 93-98 ZJ 4.0L block will work. Install the replament block, Remove and re-use as needed or required the original: intake/exhaust manifold, cylinder head, throttle body, flexplate, belt driven accessories, and engine sensors. The Jeep does not know or care where/when the original block came from.
CJ7-Tim is offline
