97 xj jerking under steady driving - JeepForum.com
post #1 of 10 Old 06-19-2013, 10:39 PM Thread Starter
gnarlyxcharlie
Lately I've been having this problem where around anywhere from 45-75 mph, if I am holding steady on the pedal, the jeep will buck almost. I feel a clunk and its as though the entire jeep moves.
Sort of a jerking sensation. And it will happen several times in a row if I hold the pedal steady.
It's really hard to explain but my brother claimed his wife's xj did the same thing and he removed the front driveshaft to fix it. I'm hoping that is not the case. Also, I've had a worn out u-joint for quite awhile if that could have anything to do with it .
gnarlyxcharlie is offline
post #2 of 10 Old 06-20-2013, 11:25 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Fix any known issues.
Is the Check Engine Light ON ?
Are all your tune-up parts fresh ? How old is your battery ?
Have you tested any of the usual suspects like the Crankshaft Position Sensor, Coolant Temperature Sensor, Throttle Position Sensor, Manifold Absolute Pressure sensor and inspected their wire plugs/wire harness ?
CJ7-Tim is offline
post #3 of 10 Old 06-20-2013, 03:45 PM Thread Starter
gnarlyxcharlie
Ordered a throttle sensor and u-joint. No check engine light. Ignition wires looked pretty old I replaced those and all the harnesses seem okay.
Battery isn't old, isn't new. Doesn't seem to be a problem as far as I can tell.
post #4 of 10 Old 06-20-2013, 06:22 PM
sluff28
1975 CJ5
so go ahead and pull the front shaft and drive it if it stops then you replace the u joints 3 of them on the front shaft.
sluff28 is offline
post #5 of 10 Old 07-09-2013, 05:07 PM Thread Starter
gnarlyxcharlie
Put in a new TPS. Didn't help. Ripped the front driveshaft. still jerks around. its incredibly annoying on the highway as it will happen five or six times in 10 second span
post #6 of 10 Old 07-09-2013, 05:13 PM
xjpete
1997 XJ Cherokee
Crack in the distributor? Put some fuel injection cleaner in also.
xjpete is offline
post #7 of 10 Old 07-10-2013, 05:01 AM
CJ7-Tim
CJ7-Tim's Avatar
Are ALL the tune-up parts fresh ? Have you tested any of the usual suspects like the Crankshaft Position Sensor, Coolant Temperature Sensor, Throttle Position Sensor, Manifold Absolute Pressure sensor and inspected their wire plugs/wire harness ? Have you cleaned and inspected all the battery wires ? Have you Load Tested the battery ?
CJ7-Tim is offline
post #8 of 10 Old 07-11-2013, 06:34 PM Thread Starter
gnarlyxcharlie
Crank sensor is new, throttle sensor is new. Cleaned battery terminals, wires seemed okay. Going to load test the battery and the alternator tomorrow.
What should I buy for a tune up. Plugs, wires, cap and rotor. Anything else? I'm new to this.
I'll see if my brother will bring me something to test the sensors with tomorrow. Both O2 sensors are also less than 2 months old. Catalytic convertor. It feels mechanical when it jerks, not like a sputter or anything.
post #9 of 10 Old 07-11-2013, 07:19 PM
xjpete
1997 XJ Cherokee
Air filter,check engine coolant when it is cool,all fluids should be checked.
xjpete is offline
post #10 of 10 Old 07-12-2013, 04:55 AM
CJ7-Tim
CJ7-Tim's Avatar
Champion Copper Top spark plugs, wires, cap and rotor, ignition coil. Throttle Body Cleaner, Air Filter.
You should also test the Coolant Temperature Sensor, and the MAP Sensor. Inspect the wire harnesses for any chafed/melted insulation, broken wires, and/or corroded wire plugs.
CJ7-Tim is offline
