97 xj heater core replacement - JeepForum.com
post #1 of 9 Old 05-23-2010, 11:12 AM Thread Starter
Mike406
1997 XJ Cherokee
Hello All. First I would like to thank you for your time. Next; Has anyone actually replaced a 97 xj heater core? I have read the the ENTIRE dash as well as steering wheel must be removed. Is this true? This was said of my grand-am as well but was not the case when I did the job. I welcome any tips or tricks that anyone can share. Thank you again.
Mike406 is offline
post #2 of 9 Old 05-23-2010, 11:23 AM
basso4735
basso4735's Avatar
1997 XJ Cherokee
Oh of course.
http://www.jeepforum.com/forum/f11/m...thread-592844/
- Includes bastard pack and cheap 3" lift info
Red 97 XJ Sport 5 Speed - Lifted 3" - Sound system - C4X4 Tow Hooks - Hella 500s
Black 96 XJ Classic - Stocker on 31s - SOLD
basso4735 is offline
post #3 of 9 Old 05-23-2010, 11:30 AM
docgatling
I haven't replaced mine, and I have a 99, so I don't know much. However, I can tell you I had to get inside the heating / cooling system to reconnect the defrost damper to its axle. The manual said the complete dash needed to be removed. I thought that was a bit silly and figured I could get it done with removal of just a few key pieces. A day later, the loss of several ounces of blood and more the a few "key peices" sitting on the drive and still nowhere near the broken part told me this was a job for the dealer. And I'll do almost anything to avoid the stealer - I mean dealer. I managed to get it done but it was not easy. however I didn't remove the steering wheel. But I had to work with the aluminum (pot metal?) dash frame in the lap!
Good luck
docgatling is offline
post #4 of 9 Old 05-23-2010, 11:34 AM
docgatling
nice write up basso. I'll pull out motors and trannies and anything else. But the dash - It think it maybe worth the cash to let someone else do this.
post #5 of 9 Old 12-04-2011, 01:39 AM
XJmallcruiser
Keyless fob?
Where can i get the keyless fob? Whats it supossed to look like?
XJmallcruiser is offline
post #6 of 9 Old 12-04-2011, 10:49 AM
XJmallcruiser
Wtf? This was supossed to be a new thread... Sorry
post #7 of 9 Old 12-04-2011, 11:52 AM
Desertwheeler
^ nice!!! Lol
2000 TJ Crawler- 5.5 lift w/14in coilovers, HP44, ARB, Cromo's, 300m Joints/D60, Detroit, D80 35spl shafts. Full hydro, OBA, OBW, Flipped D300 W/4:1 kit, custom cage etc.
2001 Cherokee Sport, 4.5 RC Longarm, 33 Duratrac's, SYE, 4:56's, Front HP30 w/Lockrite, Autopals- Sold
Desertwheeler is offline
post #8 of 9 Old 12-04-2011, 12:34 PM
XJmallcruiser
Lol well ive been smelling a real sweet coolant like smell when i turn on the ac so i was in here looking at what a pain itll be then i giess i hit reply instead of new thread
post #9 of 9 Old 12-07-2011, 05:55 AM Thread Starter
Mike406
1997 XJ Cherokee
I used Basso's writeup to do mine. The only difference is I was able to leave the steering wheel in. I used the pass shoulderbelt to hold the dash out of the way while i got my hand up inside and removed the airbox. While I had it out I changed the ac core as well. Only thing is now when I put it to defrost It doesnt blow full force, like its stuck in the middle.
Mike406 is offline
dash removal , heater core , overheating
99 cherokee heater core replacement tips / low heater output 01xjltd XJ Cherokee Technical Forum 14 06-30-2013 09:53 PM
XJ Heater Core Replacement Phoenix2 XJ Cherokee Technical Forum 0 02-01-2008 08:59 AM
heater core replacement GRDCHRKE555 XJ Cherokee Technical Forum 23 01-06-2008 02:35 AM
heater core replacement Hristo XJ Cherokee Technical Forum 9 04-13-2006 08:43 AM
XJ Heater Core Replacement tehlers2 XJ Cherokee Technical Forum 3 09-10-2003 08:26 PM
