97+ XJ Gauge Cluster Swap - Write-up/How-To
| Truck-Lite's New LED Headlamp Series | 4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed | Ruffstuff Axle Simple Swap Kit! |
#1 | |
I, like many others, couldn't stand the idiot lights Chrysler decided were satisfactory...
![]() So, I bought a used 97+ cluster to replace the pointless factory cluster. I started out by removing the "Lift Gate" light from the back of the cluster. It was recommended to me by another member as my Cherokee did not have the same bulb in the back of the cluster. I then removed three screws that attached the kick panel to the metal underside. Pull the "clips" out of the holes. ![]() ![]() Afterward, I removed the two screws that held the metal underside on. There is one on the left and one on the right side of the panel. It is to the left of the highlighted hole. ![]() Then, pull the center piece out by pulling gently on the bottom corners. The top comes loose once you have the others loosened. ![]() Next, I removed the eight screws that held the dash bezel on. ![]() ![]() ![]() ![]() Make sure you pop these "clips" loose. They just pull out. ![]() Then, detach this rubber steering shaft dust cover. It just slides apart. ![]() Gently pull the dash bezel away from the rest of the dash. It "pops" out. ![]() Now, you get to work the dash out and around the steering wheel and box cover. It's going to take some finesse to get the bezel around the light switch. I slightly bored mine out with a knife and some sand paper. At this point, you're almost home free. You simply remove the three screws holding the gauge cluster in place and pull the unit out. ![]() Swap in your new cluster and do a "system check" on the unit before you bolt everything back up. If you don't do it now... :You do the self check by completing the following process:
You're done! You now have a tachometer and fully functioning gauges! No more "dummy" lights! Post up if something isn't clear or if you have any questions. Cheers, Michael
Sex should be like a riced out civic. Slow, obscene, and really loud... |
#2 | |
1995 XJ Country 3.5" Full Traction w/ HD leafs 31x10.50 BFG M/T KM2...see specs Georgia Institute of Technology Ramblin' Wreck from Georgia Tech |
#3 |
Drivin' me nuts...
Good write-up.
You should pm Balloo93, and have it put in the Tech/FAQ sticky.
'99 Classic: "Emma" 8.25 * NP242 * Auto trans * 3" OME HD lift * IPF lenses and H4s * Uniden PC78elite JKS Discos and adjustable track bar * 31" BFG T/A KOs on 15x8 black Cragar soft 8s Tom Wood's SYE and custom drive shaft * Custom evil shark mouth skid plate * Hingeless 2-way hood vents Jeeps with Teeth #1 MN Jeeper #14 _____________________________________________ "When is the best time to do things? Who is the most important one? What is the right thing to do?" "BORN TO WHEEL" PRODUCTS FOR SALE **********More designs here********** |
#4 |
You can also use the cluster from a wrangler for this swap. I had no light issues with mine. Nice write up.
New one-2000 XJ sport- Now has 3.5" lift, Hp 30/8.25 w/4.10's, V8 Zj steering Totaled 3/18/10-'99 Black 2 door XJ DD, 3.5+" bastard lift. SOLD-'98 TJ 4 banger 5 speed, 4.88's, Hp 30 ARB'd, S35 w/Detroit and truss, RK LA's, Kilby skids and LOTS of other junk. Should have kept it! Traded for my XJ - '98 ZJ was pretty and built at one time- Hp30, 8.8 and 5" lift and other stuff. |
#5 |
98 xj 4.0L 231 t\case off road commode 4 in the floor and a fifth under the seat Eat more possum |
#6 |
Thanks for the great write up.
#7 |
I have a 97 cherokee and i want to swap out the guages to the premium cluster. i hate those stupid dummy lights. what do i need to do to swap them out, ive had some people tell me i need to rewire everthing, and others that say its plug and play,i dont know what to do.
from the looks of the pictures it looks as though it is a plug and play type of job but i want to be 100% before i buy a new one and rip my dash apart to find i need to do a bunch of other stuff
If you like it rough, do it in a Jeep! Eat, sleep, Jeep |
#8 | |
I'm forever grateful to Speedycat and RnEmOvr for their generosity |
#9 | |
4.6 stroker, 2wd, 5spd, larger sway bars front and rear, 3.55s, KJ 16's. Projected date of completion - lol www.jeepstrokers.com |
#10 |
sweet thanks, now to the fun part, tearing my dash apart to put one in.
#11 |
Does swapping clusters screw with the odometer at all cause i wanna switch to a TJ cluster but i want correct mileage.
My white Cherokee classic build thread |
#12 |
Drivin' me nuts...
Yeah, it'll give you the mileage from the TJ.
#13 |
o-well ill just have to wait till i get to my high performance class and i can build a stroker then buy a tj cluster.
#14 |
So ive been looking for a cluster to swap out and i cant find any for a reasonable price, so far the two places that i can get one charge more than 100 dollars for one
but maybe if i widen my search than maybe ill find one. what other models can i pull a cluster out of? i know i can pull it out of any 97+ XJ but are there any others
#15 |
Reading the above post it appears a TJ will work.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
