97 xj cherokee starter relay location ?? - JeepForum.com
post #1 of 5 Old 01-13-2009, 11:30 AM Thread Starter
aquaholic_
can someone tell me where the starter relay is located on my 97 xj ? i did a search for this and came up with nothing, which i thought was kinda odd. only posts i found on this was for tj's.
97 xj cherokee se, 4.0L, AW4
bad azz classic white 74 A3 corvette
retina burning red 99 A4 corvette
2500 summit white 02 avalanche 8.1L A4
voodoo blue 07 toyota fj cruiser
92 pearl white custom hd fatboy
aquaholic_ is offline
post #2 of 5 Old 01-13-2009, 02:06 PM
AZ Jeff
2014 JK Wrangler
It's on the starter proper.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #3 of 5 Old 01-13-2009, 04:04 PM Thread Starter
aquaholic_
i dont have any idea what a starter proper is, however i did find the relay. its in in the retangular black plastic fuse box located just behind the battery.
post #4 of 5 Old 01-13-2009, 04:22 PM
AZ Jeff
2014 JK Wrangler
The phrase 'the starter proper' is correct grammar for saying 'directly mounted to the starter'. I guess you missed English class the day they explained that, huh?
In all seriousness, the starter solenoid on a 97 does double duty. It engages the drive into the flywheel, and it also closes the main high-current connection to the starter windings. This is different than the older XJ's with the fender mounted Ford-type starter solenoid/relay.
AZ-Jeff
AZ Jeff is offline
post #5 of 5 Old 01-14-2009, 11:40 AM Thread Starter
aquaholic_
could you please stay out of this post. i was looking for the starter relay you loser. not the solenoid. which i found. read thread 3.
fuel pump relay location on 1987 jeep cherokee 4.0 rgjeep XJ Cherokee Technical Forum 8 12-15-2010 01:49 PM
Cooling fan relay location loyd198 XJ Cherokee Technical Forum 1 12-27-2008 08:26 PM
90 cherokee 4.0 Electric engine fan hooked up wrong, need relay location. keepishop XJ Cherokee Technical Forum 0 10-26-2008 12:17 PM
87 cherokee elec fan & starter relay dchicoranew XJ Cherokee Technical Forum 1 07-23-2007 02:30 PM
location of door locks relay - 97 cherokee? mackg@goodweb.o XJ Cherokee Technical Forum 6 10-09-2005 04:02 PM
