97 xj check gauge problems - JeepForum.com
post #1 of 3 Old 12-24-2010, 12:48 PM Thread Starter
mannyawwad
2002 KL Cherokee
i have a 97 xj and for about a week it was saying check gauges and the battery meter was going down to zero, then one night it just completly died. the next day i took the battery and alternator out and the alternator passed but the battery was done so i got a new one but i put it in and its still saying check gauges once in a while, do i need a new alternator too????
mannyawwad is offline
post #2 of 3 Old 12-24-2010, 02:11 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
It could be the connectors on the back of the gauge cluster. The 97 is known to have this problem.
xjfever is offline
post #3 of 3 Old 12-25-2010, 01:55 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Alternators can test good and still not be good enough. You need to use your Volts/Ohms multimeter and test the alternator output. It should output between 12-14 volts at idle. If you don't have a multimeter, spend $15 and get one at the hardware store.
Check the wires and connection between the alternator, battery, and starter. The connections should be clean and tight and the wires and connectors should be in good condition.
CJ7-Tim is offline
alternator replacement , battery , xj
Temperature Gauge is posessed / Check Engine on jedired XJ Cherokee Technical Forum 36 06-07-2011 01:47 PM
Check Gauge Light - strange... aardvark101 XJ Cherokee Technical Forum 4 03-20-2010 09:59 AM
check gauge lite comes on then off mikemm XJ Cherokee Technical Forum 0 12-07-2008 11:49 AM
check gauge ...?? rapha XJ Cherokee Technical Forum 4 11-09-2005 09:49 AM
check gauge light xjcountry XJ Cherokee Technical Forum 2 05-30-2005 12:22 PM
