97+ tank into a 95 or older xj? - JeepForum.com
post #1 of 4 Old 02-11-2011, 03:58 PM Thread Starter
The_Blacksmith
1993 XJ Cherokee
for obvious reasons the newer tanks are plastic, vs the older rusty metal ones.
can I use the 97 + pump, is the pump the same? should I keep my 93 and 95 pumps as spares?
the sending unit on the 97 will work with the 95 gauges?
ect ect? ?
Thanks Chris!
The_Blacksmith is offline
post #2 of 4 Old 02-11-2011, 08:00 PM
scott_jeep
I believe someone over on NAXJA was able to get the newer tank on but it would never read right. Something about the systems being completely different.
I know its not too much help but you might want to search over there for some additional info.
scott_jeep is offline
post #3 of 4 Old 02-11-2011, 08:46 PM
ChicoXJ
1986 XJ Cherokee
The 97+ tanks have an internal regulator and one line to the fuel rail. The earlier ones had two lines, one being a return line from the regulator at the fuel rail. It would just be easier and better to use the proper tank.
ChicoXJ is offline
post #4 of 4 Old 02-12-2011, 04:48 AM Thread Starter
The_Blacksmith
1993 XJ Cherokee
the proper tanks suck tho. I've had 2 with holes in them already.
I guess its back to looking for a stock tank.
Someone want to buy a 97 + tank?
Thanks Chris!
Older model factory tank skid on newer model? JGriff99xj XJ Cherokee Technical Forum 3 02-17-2010 02:08 PM
new tank and pump into older (90) XJ.... gauge backwards! noconesXJ XJ Cherokee Technical Forum 2 10-02-2009 08:00 AM
For those of us who have a 95 xj or older XJ95mlake XJ Cherokee Technical Forum 7 05-05-2006 12:26 AM
96 and older XJs and gas tank skids Dannyboy18 XJ Cherokee Technical Forum 13 10-02-2005 10:46 AM
Who's gone from an older XJ to a '96+? BoxOnRox XJ Cherokee Technical Forum 3 04-25-2005 04:02 PM
