#1 | |
97+ stock fog light switch
Anyone know why the 97+ factory fog light switch go bad?I have replaced mine 3 times now and think i have an idea on what the cause of the switch goin bad but not sure.
#2 |
Little Red Menace
Not that many. Start tracing the wiring harness back and find the problem.
93 Sport Beer is proof that God loves us and wants us to be happy............Ben Franklin Specs in Profile. http://www.cardomain.com/ride/325707/1 http://www.cardomain.com/ride/2406854/1 |
#3 |
Well i think i found out the cause of the switch problem.There are two lights inside the switch and ever time my switch's go bad the rocker inside the switch is melted around the bulb, the bulb on the bottom with the rubber thing on it.So when i get a new switch i will remove the bottem bulb and see how long it last.It sad to say but i love working with electrical and i have checked the harness and anything from the switch too the fogs and nothing.So its the switch.I will post if the switch goes bad..Thanks for the help
#4 | |
Universal Cereal Bus
My fog light switch went out when I put 100w bulbs in the housings instead of the OEM 60 watt bulbs. I thought jeep would have used a relay but I guess they have all the current go through the switch because the inside of it had melted.
2001 Cherokee Limited My Build Thread: 6" IRO Long Arms and coils, JKS ACOS, OME 4" Leaf springs w/1.5" Teraflex shackles, RC Shackle Relocation Brackets, ~34" BFG KM2, RC Quick Discos, Fox 2.0 IPF Shocks, Rear Disk Brakes, 60mm Bored TB, Cobra Injectors, Rugged Ridge Header, 2.5" Exhaust with Borla Muffler |
#5 |
Go Jeepin
97-01, it is very common for the fog lamp switch to burn out. Usually the contacts go bad. The design of the switch and the light circuit is not the greatest and the resistance in the circuit leads to excess heat that burn the switches. You best solution would be to rewire the circuit so that the factory fog lamp switch operates a relay that handles the 12v power for the fog lamps removing the stress from the switch itself.
. FOR SALE: Wide Track CJ-7 Dana 44 rear axle. PM me for details A Government big enough to give you everything you want, is a Government big enough to take from you
everything you have. The course of history shows that as a Government grows, Liberty decreases. |
#6 | |
FWIW, if any of you have switches you DON'T want, send them my way and I will replace the inards and get em going again ![]()
'99 XJ Sport MY BUILD Thank You Hooligan!!! XJ/TJ Heaterbox Seals for sale!!! NIB! Official Mopar made in USA! |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
