Quantcast 97+ metal tail light housings : build - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > 97+ metal tail light housings : build
Truck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededRuffstuff Axle Simple Swap Kit!
Old 10-19-2009, 07:47 PM   #1
skyway0018746
ok guys so my search on metal tail light housing for our 97 + has led me to eather too high of a price or none at all so i got to looking at the stock tail lights and it doesent look that hard, so i am in the process of designing them and wanted some input on what kind of lights would look good. and if all goes well i have a lot of stock to make a couple extra so ...
im not promising that they will follow the body line like the factory but good enough to get the job done
here is what i have so far
http://i38.tinypic.com/vwzyvp.jpg
7" long arm lift, HNT sye , herculined inside, bush wacker fender flares now geared and locked !!!
62 mm bored throttle body's fs - pm
skyway0018746 is offline   Reply With Quote
Old 10-21-2009, 07:12 PM   #2
skyway0018746
ok guys i guys i have it all drawn out and looks pretty good over the stock tail light just have to cut it out and see how it goes.
i found these lights: Red LED Oval Trailer Truck Stop Turn Brake Tail Lights:eBay Motors (item 140353697044 end time Oct-30-09 09:46:49 PDT)
what do you guys think of them?
xj tail light Pictures, xj tail light Images, xj tail light Photos, xj tail light Videos - Image - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
Old 10-25-2009, 08:16 AM   #3
skyway0018746
any one have any input in these im almost done designing them and ready to cut them out on monday
Old 10-25-2009, 09:55 AM   #4
mortalenema
Drivin' me nuts...
mortalenema's Avatar
What are you gonna do for the backup lights?
Sounds like a cool build. I can't wait to see them done and see the total cost.
'99 Classic: "Emma"
8.25 * NP242 * Auto trans * 3" OME HD lift * IPF lenses and H4s * Uniden PC78elite
JKS Discos and adjustable track bar * 31" BFG T/A KOs on 15x8 black Cragar soft 8s
Tom Wood's SYE and custom drive shaft * Custom evil shark mouth skid plate * Hingeless 2-way hood vents
Jeeps with Teeth #1
MN Jeeper #14
_____________________________________________
"When is the best time to do things? Who is the most important one? What is the right thing to do?"
"BORN TO WHEEL" PRODUCTS FOR SALE
**********More designs here**********
mortalenema is offline   Reply With Quote
Old 10-25-2009, 10:06 AM   #5
skyway0018746
i have put them in just havent put i pic up
im p'lanning on using these (2) White 2.5" Round 13 LED Mini Reverse Backup Lights:eBay Motors (item 140352678771 end time Oct-25-09 17:04:52 PDT)
dont know if they will any better than stock but well see
im hoping to keep it under 200 with lights included
Old 10-25-2009, 11:40 AM   #6
XJChris98
It looks like your on the right track with everything. Id suggest maybe making the outside edge of your lights an arc though, as the body line will follow this much better. The factory taillights also 'taper' in as they get closer to the rear hatch (yes, this makes it a PITA to make), but can be done with a little time and attention to detail.
Heres what I did:
From 3-D model
To the real thing
I used the oval lights and white reverse lights from Super Bright LEDs - LED Products and Accessories
The reverse lights are no way near as bright as the factory ones, but I didnt care to much about that...just needed something to keep me legal.
If you plan on wiring up the oval lights for stop, tail, and turn lights (i.e eliminating a seperate light for a turnsignal), then you'll need this to wire them up:
Tow Ready Website - 119130
It HAS to be this converter for the lights to work. Dont as me how or why, but I spent ALOT of time reading around and seeing what did and didnt work.
XJChris98 is offline   Reply With Quote
Old 10-25-2009, 11:57 AM   #7
skyway0018746
yeah mine on paper looks like yours so should look good, saw super brite's web site thismoring but there prices are higher then the ones i found so ill try the ones i found and see. might have to go back to good old incandescent lights
i have the big radius on the out side line it some thing like 99.5" dia.
Old 05-17-2010, 12:18 AM   #8
Back_In_Black
All Black Everything.
Back_In_Black's Avatar
please tell me where you got that bumper sticker, i want one!!!!
Back_In_Black is online now   Reply With Quote
Old 03-28-2011, 02:09 PM   #9
xj287
you have a build thread, like step by step? they look AWESOME!
Recovery Crew Club #1
Night Crew #254
RED JEEP CLUB #545
1999 XJ 4 door 4.0 4.5in lift 33x12.50 more mods will be listed
1996 ZJ All stock currently debating what lift and how much to trim!
xj287 is offline   Reply With Quote
Glock Forum
