97' fuse block diagram - JeepForum.com
post #1 of 12 Old 09-13-2005, 05:42 PM Thread Starter
jperry
Does someone have a fuse block diagram for a 97'. I can't find the right layout diagram.
Here's a pic of the fuse block (under the ps kick panel)
http://www.jpimages.net/jeep/fuse.jpg
jperry is offline
post #2 of 12 Old 09-14-2005, 06:18 AM
FitchVA
Jeeper 4 Life
FitchVA's Avatar
copied from another thread on another forum.
...for a 2000 xj - i would guess it'd be the same setup
1 25 Power Outlet
2 25 Cigarette Lighter
3 10 Left Headlight High Beam
4 10 Left Headlight Low Beam
5 10 Right Headlight Low Beam
6 5 Instrument Panel Dimmer?
7 10 Left Parking Light
8 Open
9 10 Headlight Delay? Overhead Cassette Changer?
10 Open
11 30 Run / Start Ignition? Daytime Running Lights
12 10 Rear Window Defrosters / Turn Signal / Hazard Flashers
13 Open
14 10 Heated Mirrors
15 25 Power Door Locks
16 10 Right Headlight High Beam
17 15 Radio
18 Open
19 10 Starter Relay
20 10 Trailer Tow Package
21 15 Horn Relay?
22 20 Rear Wiper
23 10 Right Parking Light
24 Open
25 15 ABS / Climate Controls / Cooling Fan? / Brake Switch
26 10 Airbag Control Module
27 10 Airbag Control Module
'98 xj sport (trail toy) |
'98 xj classic (dd'er) |
'89 mj tinker toy |
FitchVA is offline
post #3 of 12 Old 09-14-2005, 06:32 AM
Atari.fan3000
Atari.fan3000's Avatar
What is with the questionmarks? does that mean that you are unsure about what goes there
Atari.fan3000 is offline
post #4 of 12 Old 09-14-2005, 07:01 AM
FitchVA
Jeeper 4 Life
FitchVA's Avatar
i dunno. i didn't make the post. i was just quoting the post i found on another message board.
'89 mj tinker toy |
FitchVA is offline
post #5 of 12 Old 09-14-2005, 08:14 AM
Atari.fan3000
FitchVA would you happen to have an owner manual, I am sure that it must be in the owners manual
post #6 of 12 Old 09-14-2005, 08:16 AM
firefighter1c57
SPACE FOR RENT
firefighter1c57's Avatar
I have a owners manuel for a 97.
From the 97 manuel.
Match the numbers from above.
and under hood box.
again match the numbers.
and from the back page, to hopefully settle the great which tranny fluid debate.
or equivalent labeled Dexron III Mercon. I'll stick with what my manuel tells me.
Hey Balloo, any chance you can pull the images and add them to the stock stickys so we could link from there when replying to fuse box threads. We seem to get a lot of them. If so I have hosted in my pictures here on Jeepforum, pull em if you can.
I bring NOTHING to the table.
Last edited by firefighter1c57; 09-14-2005 at 09:01 AM. Reason: edited to add the pictures.
firefighter1c57 is offline
post #7 of 12 Old 09-14-2005, 08:40 AM
FitchVA
Jeeper 4 Life
FitchVA's Avatar
I have one for my '98.
if i remember or have the time, i could get it on my lunch break
'89 mj tinker toy |
FitchVA is offline
post #8 of 12 Old 09-14-2005, 08:41 AM
Atari.fan3000
Would it happen to have the fuse box diagram?
post #9 of 12 Old 09-14-2005, 09:02 AM
firefighter1c57
SPACE FOR RENT
bmp to top for pictures.
post #10 of 12 Old 09-14-2005, 09:09 AM
Atari.fan3000
THank you cruzmyxj you Rock that is just what I was looking for
post #11 of 12 Old 09-14-2005, 02:23 PM
ElPaca19
ElPaca19's Avatar
Wow I love the search feature. I just went out to my car (I am at work) and wanted to see if I could figure out which fuse was for the rear wiper (which is not working) but I do not have any fuse block diagrams in either my Haynes manual or owners manual. Rather then post a thread I used the search. It is amazing more people don't use it. Thanks all.
Mine: 2000 Black XJ Sport, D30 and 8.25 w/ Yukon 4.56's, 4.5" RE SF (plus a 1.75" Daystar spacer, 1.75" Teraflex shackle), OME LT Shocks, SJ SS, M.O.R.E Steering Box Brace, JKS Adj Track Bar, JKS Discos, AA SYE and TW CV DS, 15x8 Black Rock Krawlers, 33x12.5x15 Maxxis Bighorns, Bushwackers, ARB Bumper, 45 x 60 Surco rack, AJ's Super Rails, Class III rear hitch, 4 100w Hella 500's, Hella 550s, Hella Vision Plus, CB w/4ft Antenna, removable hood deck port, Borla cat back etc.
ElPaca19 is offline
post #12 of 12 Old 09-14-2005, 03:04 PM Thread Starter
jperry
Rock ON!!....now i can finally figure these out.
Thanks cruzmyxj.
jperry is offline
fuse block melted & fuse didnt blow 92BEATER XJ Cherokee Technical Forum 4 08-23-2011 08:09 AM
Need wiring diagram for '98 passenger fuse box, fuse #11 johnsoninc86 XJ Cherokee Technical Forum 2 11-09-2009 06:01 PM
Need 96 xj fuse block diagram 88JeepLimited XJ Cherokee Technical Forum 0 10-20-2009 12:26 PM
fuse block diagram hevybluzer XJ Cherokee Technical Forum 8 12-17-2007 10:15 PM
Wanted: 94 Fuse Block Diagram Moose_God XJ Cherokee Technical Forum 3 11-26-2005 09:30 PM
