97+ drivers window/lock switch box
| Truck-Lite's New LED Headlamp Series | 4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed | Ruffstuff Axle Simple Swap Kit! |
#1 | |
I have the same problem many other people have with the window lockout switch failing. I read all the threads about it and know how to fix it by bypassing the lockout. I want to see if i can crack open the actual switch box and see if i can fix it without bypassing the lockout but cannot figure out how to open the actual switch box. I got all the screws and clips undone around the outside but it seems like something is keeping it together in the middle. Do the actual switches pop off somehow. I tried but they don't want to budge.
Any help would be great!
2000 Cherokee Sport 10x,xxx miles strong, 4.0,AW4,NP231,8.25,3" homebrew, 4 wheel discs, Moabs, MT/R's
#2 |
If I've read your question right the removal of the top switch covers can be a B***ard. Here's how I did it.
http://www.jeepforum.com/forum/f11/power-window-switch-repair-writeup-444977/ I never did figure out how the PCB would separate from the bottom plastic cover to be able to remove the switch for replacement. |
#3 |
Seems like a lot of work for a less than 15 minute fix.
Click here for the Window Lockout Bypass
Full Specs 2K XJ - 6" lift w/ 34s '98 XJ Laredo - Stock (and staying that way) '71 M151 I'm a proud member of MyUniBody |
#4 |
i was trying to bypass the bypass.... and i figured out that my problem was a loose connection between the switch box and the plug... a little electronics cleaner... strategic placement of RTV... and
did the trick! now i have a lockout and all the windows work! ![]()
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
