97 Cherokee wiring diagrams - JeepForum.com
post #1 of 10 Old 07-01-2010, 01:45 PM Thread Starter
rnrandy
Anybody out there have any wiring diagrams for the powertrain for 97 xj im having problems with? I dont want to buy them off the internet and the garbage haynes book i have thats supposed to cover 84-01 doesnt have anything for wiring past OBD1, so i figured i would ask my fellow jeepers. thanks
rnrandy is offline
post #2 of 10 Old 07-01-2010, 06:43 PM
AZ Jeff
2014 JK Wrangler
the wiring diagrams for the later XJ's are MANY pages long. Even the 'powertrain' section is probably 30+ pages. If you give us some better details on what you are trying to fix, I might be able to email you some specific pages in PDF format.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #3 of 10 Old 07-02-2010, 12:05 PM Thread Starter
rnrandy
well, its a combo of a few things. im having problems with the o2 sensors, neutral safety sw, and a misfire in cyl #2 with about 8 or so codes total. the o2 sensors are giving me the same codes for both sensors (shorted to voltage a heater code) and a few for the neutral switch. being as the trucks specialty is mudd and flying through the air, i suspect broken wires and corrosion as some potential problems. ive already fixed some wires going to the computer and the upstream o2 but codes keep comming back. so i want to check if they share any of the same circuitry being as its unlikely that both sensors fail with the same codes at around the same time. the o2 sensors have already been changed a few times by my buddy (its his rig) so they "should" be fine. so i guess what i need is the o2 sensor diagrams, the ones for the neutral safety sw, and i would like to have the pin out chart for the computer connector.
rnrandy is offline
post #4 of 10 Old 07-05-2010, 08:42 PM Thread Starter
rnrandy
so i had a chance to look at the jeep this weekend and figured out what the problem with the o2 sensors was. i looked at some wiring diagrams that i was able to find and i noticed that there was a fuse for the o2 sensors. i checked it and sure enough it was blown. put a new one in and went through the drive cycle to run the o2 sensor monitor and all the codes for the o2 sensors went away. now all i have to do is figure out the issue with the misfire.
rnrandy is offline
post #5 of 10 Old 07-05-2010, 09:29 PM
XJ Jay
clean or replace the NSS, cylinder 2 misfire, check the easy ones. confirm spark and injector pulse. check the state of tune, you may have a bad plug, but they all may need replacing. maybe even check compression in the number 2 hole while you have the plug out.
HISWhite 99 XJ Sport
5" RC/ProComp lift, Serious long arms, 33" Cooper STTs, Soft 8s, 4.56s, Aussie locked D30, LSD 8.25,discos, armoured blah blah blah, HP44/9" coming soon
HERSBlack 08 JK Unlimited X, Teraflex 1.5" leveling kit, Rubi coils 35" TSRs and 5.13s
XJ Jay is offline
post #6 of 10 Old 07-05-2010, 10:21 PM Thread Starter
rnrandy
yeah i plan on doing all that when i get a chance. i was only worried about the o2s codes because they came on right off the bat and he needed to smog it. so now that they arnt there i can smog it when i get to work in the morning because the misfire code takes a while to come on. ive just been really busy so i wanted to tackle the important stuff. ill probly check everything tomorrow after work. i know he did a tune up not too long ago so the cap wires and rotor should still be fine, the plugs im not too sure about.
rnrandy is offline
post #7 of 10 Old 07-05-2010, 10:32 PM
XJ Jay
if you have a misfire, youll probably fail you smog testing. also the "important stuff" would be the misfire
XJ Jay is offline
post #8 of 10 Old 07-05-2010, 10:45 PM Thread Starter
rnrandy
nope, suprisingly its not failing for emissions, just the functional check on the computer. and the only thing it was failing for in the functional was the o2 sensor codes. like i said, it takes a while for all the other codes to come back. and the misfire code pops up when you stab the throttle in neutral and let off imediatly and the engine runs rough for a second then goes back to normal. or if you slow down realllly quick. sometimes it will set a p0300 in addition to the p0302. i think the cyl 2 misfire may be an injector because the computer triggers the injector so much faster when you stab the throttle that it heats it up and takes a second for it to cool.
rnrandy is offline
post #9 of 10 Old 07-06-2010, 05:31 AM
maxwedge
[URL="http://www.greatlakesxj.com/tech.html''] try out this website let me know how it works out for you.
maxwedge is offline
post #10 of 10 Old 07-06-2010, 11:46 AM Thread Starter
rnrandy
yeah, i looked into that forum before. doesnt really seem that active though.
rnrandy is offline
93 XJ Wiring diagrams wickedx XJ Cherokee Technical Forum 5 10-07-2011 07:54 AM
1999 cherokee classic wiring diagrams? deandy77 XJ Cherokee Technical Forum 1 06-16-2010 03:00 AM
1993 Jeep Cherokee wiring diagrams macs XJ Cherokee Technical Forum 0 05-29-2008 05:25 PM
wiring diagrams slayer2000 XJ Cherokee Technical Forum 2 05-20-2007 08:43 PM
Help, wiring diagrams needed for a 93 Cherokee wwsupercars XJ Cherokee Technical Forum 1 06-17-2003 04:57 PM
