97' Cherokee keyless entry - JeepForum.com
post #1 of 4 Old 06-26-2013, 10:39 PM Thread Starter
jeepyaya2010
I just bought a 97 'cherokee and it came with keyless remotes that did not have batteries. I've bought cr2016 and cr2025 batteries and neither of them seem to work. Do i not have the right battery or do the remotes need to be programmed again?
jeepyaya2010 is offline
post #2 of 4 Old 06-27-2013, 04:36 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Consider that the remotes are broken, or that they are not the original ones, and need reprogramming. 1997-2001 the remotes can only be programmed at the Dealership.
CJ7-Tim is offline
post #3 of 4 Old 06-28-2013, 04:11 AM
MossGreen97
1997 XJ Cherokee
The remotes for the '97s use (2) 2016 batteries one on top of the other. Once installed, you can check to see if they work at Autozone or Advance Auto. Look for broken contacts inside the remote. Some newer remotes seem to break contact easily. This can be fixed with a soldering iron.
'97 XJ Moss Green Metallic. 2DR. 2WD AW4 tow pkg.,3.73 gears. Firestone Destination A/T 225/75x15.
MossGreen97 is offline
post #4 of 4 Old 06-30-2013, 09:31 AM Thread Starter
jeepyaya2010
Thanks that worked wonders. One of the two remotes works again. That's good enough for me. Cheers!!
battery , cherokee sport , help needed , keyless entry
