Quantcast 97' cherokee with check engine light - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > 97' cherokee with check engine light
GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp SeriesRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 10-01-2004, 10:07 PM   #1
Jeep Jerry
Hi Guys,
I recently had my T.P.S. , fuel filter, and fuel pump replaced on my 97' Cherokee I-6 4.0 L engine about 2 weeks ago. I had this done because of an intermittent rough idle, and engine backfire. I originally tried to correct this problem by using Proguard fuel injection cleaner, and running BP (Amoco) 93 octane rated ultimate. My assumption was that I had obtained some bad fuel, but when the 93 octane and Proguard did not improve my problem, my Jeep was taken to a local independent mechanic. At first , my mechanic could not get the problems of an erractic idle, and engine backfire to repeat. However, after a few days in his shop, the problems finally surfaced. He ran diagnostics on the Jeep, and concluded that the Cherokee must have a faulty T.P.S., fuel pump, and filter. He replaced all of these items for me at the tune of $1200. Much to my chagrin, two weeks later (today), I am now having the same problems again (ie. erractic idle, engine backfire, jerking hesitation with acceleration ). However, this time, I have a check engine light on the dash that want go away. To make matters worse, this problem is intermittent once again. I am totally exasperated by this problem. I am very hesitant about taking my Jeep into my local mechanic again. I really don't want to get torched for another $1200 bucks. Does anyone have a clue as to what is going on with my Cherokee? This vehicle has given me good service, and I only have 86K on it. I really would like to keep it running, but at the same time, I don't want to sink more cash in it as part of a guessing game.
Jeep Jerry
Jeep Jerry is offline   Reply With Quote
Old 10-01-2004, 10:18 PM   #2
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Swing by a AutoZone and have them pull code on it. The OBDII should store any codes tripped.
Have you ever replaced the O2?
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Old 10-01-2004, 10:28 PM   #3
Jeep Jerry
Thanks Balloo93 for the tip. I have never had the O2 sensor replaced. My spark plug wires and spark plugs were replaced at 60K. My local mechanic ruled out faulty spark plug wires as well.
Glock Forum
