97 4.0 engine swap - JeepForum.com
post #1 of 5 Old 10-13-2012, 08:53 PM Thread Starter
hagenjc9
1990 MJ Comanche
97 4.0 engine swap
Hey everyone, I'm looking at swapping engines between my 2 Cherokee's. One is a 99, 4.0, with an aw4, the other is a 97, 4.0, with an ax-15. My question is how much of a straight up swap will it be, and does having different transmissions affect the swap at all.
P.S. I am only swapping engines so the trans are staying in the Cherokee's.
Thanks
hagenjc9 is offline
post #2 of 5 Old 10-13-2012, 11:43 PM
GetLifted
What engine is going in what year?
GetLifted is offline
post #3 of 5 Old 10-14-2012, 08:50 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Originally Posted by hagenjc9 View Post
........ question is how much of a straight up swap will it be, and does having different transmissions affect the swap at all.
Thanks
The engine blocks are interchangeable. Most or all of the sensors are the same. The flywheel may need to be changed.
Re-use or purchase any original parts or sensors and install on the donor engine as needed/required.
CJ7-Tim is offline
post #4 of 5 Old 11-18-2012, 07:07 PM
DIEMS_94YJ
the 97 4L engine will not have the ear on the bottom right front of the engine block to bolt a/c compressor on.. i just pulled a 98 GC engine and tried to install it into my 02 GC, and it will be very difficult if i can modify it to work.. the cylinder head wont have the holes to bolt the ignition coil rail to it (not a huge deal) and almost every accessory swapped.
im hoping someone will chime in who has successfully done this already, as these 99-04 engines are rare, and apparently weak in the pistons, or piston skirts. I pulled the pan off my 02 4L engine and the piston was in around 100 pieces :/
DIEMS_94YJ is offline
post #5 of 5 Old 11-18-2012, 08:46 PM
CJ7-Tim
CJ7-Tim's Avatar
DIEMS_94YJ, posting in the correct section of the Forum will help you find the right answers. This is the XJ Cherokee sections and from your reply I would guess you want to be in the WJ Grand Cherokee section.
This is the correct XJ engine swap info.
4.0L Engine Block Interchange
Any 1990-2001 XJ Cherokee or 1993-98 ZJ Grand Cherokee 4.0 L engine blocks will interchange.
Remove and re-use as needed or required: Intake/Exhaust manifolds, flex plate, cylinder head, distributor-less ignition or distributor assembly, fan belt driven accessories, sensors. If your donor engine has the distributor-less ignition, the parts can be removed and a distributor re-used and installed in it place.
If you have a cracked 0331 head, buy a good used redesigned and more durable TUPY 0331 head from a 2002+ 4.0L TJ Wrangler or WJ Grand Cherokee.
0331 head interchange:
XJ Cherokee '00-01
WJ Grand Cherokee 99-04
TJ Wrangler 00-06
Non XJ/ZJ engine block interchange:
TJ Wrangler 00-06
1990-2001 XJ and 1993-98 ZJ 4.0L engine blocks interchange. 2000+ TJ and 1999+ WJ 4.0L engine blocks interchange. XJ/ZJ and WJ/TJ engine block DO NOT interchange, (however, 1997-1999 4.0L TJ Wrangler blocks will fit in XJ/ZJ).
TJ/WJ 4.0L Engine blocks underwent clean sheet design changes effective in the 1999 WJ Grand and 2000 TJ Wrangler. These re-designed WJ/TJ engine blocks are not interchangeable with XJ/ZJ blocks. The motor mount bolt holes and belt driven accessory mounting bolt holes are in different locations, or not present at all, TJ/WJ vs. XJ/ZJ.
CJ7-Tim is offline
4.0 , cherokee , swap , xj
