97-01 Automatic Shifter Knob Removal & Replacement - JeepForum.com
post #1 of 14 Old 05-22-2011, 06:03 AM Thread Starter
gabejeep
1997 XJ Cherokee
I think I broke my automatic shifter knob when trying to remove it from the assembly. I was trying to remove the center console and needed to remove the shifter handle to get it out.
Does anyone know how to reinstall this knob? It appears as though my button is still working ok, but the knob doesn't seem to attach properly to the shifter assembly.
I think the shifter handle is broken. Do you guys think I need a whole new assembly or just the shifter handle?
Attached are some photos:
Thanks!
-Topianno
gabejeep is offline
post #2 of 14 Old 05-23-2011, 12:07 AM
Veeb0rg
1995 XJ Cherokee
looks like the plastic retainer in the handle broke, find yourself a new handle and you should be good to go.
Veeb0rg is offline
post #3 of 14 Old 05-23-2011, 12:51 AM
sbxj
sbxj's Avatar
could you make the pics larger please
'01 XJ 2DR Sport
'99 WJ Laredo, 4.0L with HID Retrofit
sbxj is offline
post #4 of 14 Old 05-24-2011, 10:16 AM Thread Starter
gabejeep
1997 XJ Cherokee
Does anyone know how to install a new handle?
gabejeep is offline
post #5 of 14 Old 05-24-2011, 11:50 AM
chriskeenan
reverse the way you uninstalled the old one, it just pops on and off.
chriskeenan is offline
post #6 of 14 Old 05-24-2011, 12:00 PM Thread Starter
gabejeep
1997 XJ Cherokee
I broke it when I removed it. I don't want to break it again reinstalling a new one. Anyone have any idea how to put this thing back on?
gabejeep is offline
post #7 of 14 Old 05-24-2011, 12:55 PM
chriskeenan
acquire "new" handle, place on to shifter rod, smack with hammer/rubber mallet/hand until seated on rod, enjoy.
I'm not joking when i say it pops off and back on, most people hit them selves in the face pulling up to remove them, it takes a good bit of force.
post #8 of 14 Old 05-24-2011, 04:36 PM
skyway0018746
evean better when there no back seats
yeah just place the new one on and give it a hit with your palm or a hammer
7" long arm lift, HNT sye , herculined inside, bush wacker fender flares now geared and locked !!!
62 mm bored throttle body's fs - pm
skyway0018746 is offline
post #9 of 14 Old 05-25-2011, 11:40 PM Thread Starter
gabejeep
1997 XJ Cherokee
Hey Skyway,
Do you think my old one might still work? Is there any specific way it fits on? Or do you just pound away at it?
gabejeep is offline
post #10 of 14 Old 06-03-2011, 12:01 AM Thread Starter
gabejeep
1997 XJ Cherokee
Well, I put it on there and smacked it with a rubber mallot to try and get it fitted on there. The plastic broke on the handle and the lever, so turns out thats bad advice. i had to order a whole new shifter assembly...
gabejeep is offline
post #11 of 14 Old 06-03-2011, 06:40 PM
keepishop
1989 XJ Cherokee
Pretty sure you hit it crooked. I've lots a tab or two inside my handle, but it's been working fine.
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap,
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline
post #12 of 14 Old 06-03-2011, 08:05 PM
lilnapsak
1997 XJ Cherokee
did you use a mallet or a heavy steel hammer? but honestly thats the way you get it back on.. just smack it. id cancle that shifter assembly order and just grab a handle out of one at the junkyard. or you can get one from a grand cherokee.
lilnapsak is offline
post #13 of 14 Old 06-03-2011, 09:26 PM
chriskeenan
junkyard is the way to go, i got a ZJ handle for like 1$, the whole assembly would probably be about 10-30$
post #14 of 14 Old 06-03-2011, 09:41 PM
GregB_00XJ
it should pop off pretty easily with a little force (as stated watch your face). I did mine the first time and it came off easily with mild force and went back on the same way.
I hear the offset Grand Cherokee handles are a bit nicer and fir the Cherokee shifter.
- 2005 Jeep Grand Cherokee LTD 5.7L WK -
____=__=
l l ,[_____],
l---- L -[]lllllll[]-
()_) ()_)--o-)_)
GregB_00XJ is offline
automatic , handle , shifter
Automatic shifter removal kdiesburg XJ Cherokee Technical Forum 3 02-12-2011 11:48 AM
B&M 80776 Sport Shifter Automatic Shifter xjbuilder00 XJ Cherokee Technical Forum 2 03-06-2010 10:32 PM
Manual Shifter Knob Removal? THEANGRYAX XJ Cherokee Technical Forum 5 02-09-2010 07:15 PM
Automatic Trans Shifter Knob JeepisRandy XJ Cherokee Technical Forum 3 04-01-2007 05:48 PM
Taking off AUTOMATIC -=-=-=-=-=-=-=-= knob? zerphyte XJ Cherokee Technical Forum 21 12-01-2004 09:39 PM
