96xj missfires need help - JeepForum.com
post #1 of 9 Old 11-19-2012, 08:15 AM Thread Starter
93fordguy
i have a 96 jeepxj that i cant get to run right. i put new plugs cap rotor wires and crank sensor and nothing helped. it starts fine but when you put it in drive and go to hit the gas she starts to spit and pop to the point where i cant go anywhere. ive tried everything i can think of with no luck. so any help would be great thanks o and it only has 140,000ish miles on it
93fordguy is offline
post #2 of 9 Old 11-19-2012, 08:50 AM
GetLifted
The fix is towards the end http://www.jeepforum.com/forum/f11/w...45/?highlight=
Good luck! I hope that's it
GetLifted is offline
post #3 of 9 Old 11-19-2012, 10:29 AM Thread Starter
93fordguy
thanks for the link it made it help it a bit. i dident have a volt meter so just jumped the wires. made a big difference i can spin the 33s that rare on it right off. but still breaks up at like 3/4 to wot.
post #4 of 9 Old 11-20-2012, 08:57 AM
GetLifted
WOW glad my thread helped!
3/4 to WOT sounds like MAP.
post #5 of 9 Old 11-20-2012, 06:34 PM Thread Starter
93fordguy
is there any way i can check the map sensor or do i have to just go buy one. and just wondering what am i suposed to have for fuel pressure?
post #6 of 9 Old 11-20-2012, 07:22 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Map sensor can be tested with a manual and a meter. And be sure that the vacuum line leading TO the map sensor is in good shape and pulling good vacuum.
For a 96, you should have 49 psi of fuel pressure, plus or minus 5 psi. Must be verified with a gauge; no shortcuts!
You also need to be sure that your "throttle position sensor" is working correctly. If you have good throttle response to a certain point and then it falters, the TPS is suspect. More on that below.
The throttle position sensor is connected to the throttle shaft on the throttle body. It sends throttle valve angle information to the PCM. The PCM uses this information to determine how much fuel the engine needs. The TPS is really just a simple potentiometer with one end connected to 5 volts from the PCM and the other to ground. A third wire is connected to the PCM. As you move the accelerator pedal with your foot, the output of the TPS changes. At a closed throttle position, the output of the TPS is low, about a half a volt. As the throttle valve opens, the output increases so that, at wide open throttle, the output voltage should be above 3.9 volts. Testing can be performed with an electrical meter. Analog meter is best. You are looking for a smooth sweep of voltage throughout the entire throttle band. While slowly opening and closing the throttle, take note to the movement of the voltmeter needle. There should be a direct relationship between the needle motion to the motion of the throttle. If at anytime the needle moves abruptly or inconsistently with the movement of the throttle, the TPS is bad
You should have 5 volts going into the TPS. At idle, TPS output voltage must be greater than 200 millivolts. At wide open throttle (WOT), TPS output voltage must be less than 4.8 volts.. The best is to use an analog meter (not digital) to see if the transition from idle to WOT is smooth with no dead spots. With your meter set for volts, put the black probe on a good ground like your negative battery terminal. With the key on, engine not running, test with the red probe of your meter (install a paper clip into the back of the plug of the TPS) to see which wire has the 5 volts. One of the other wires should show .26V (or so). The other wire will be the ground and should show no voltage. Move the throttle and look for smooth meter response up to the 4.49 at WOT.
Perform the test procedure again and wiggle and/or tap on the TPS while you watch the meter. If you notice any flat spots or abrupt changes in the meter readings, replace the TPS.
The TPS is sensitive to heat, moisture and vibration leading to the failure of some units. The sensor is a sealed unit and cannot be repaired only replaced. A TPS may fail gradually leading to a number of symptoms which can include one or more of the following: -
NOTE: The throttle position sensor is also DIRECTLY involved with transmission shifting characteristics! It should be verified early in the troubleshooting process, when a transmission issue is suspected!
• Poor idle control: The TPS is used by the ECU to determine if the throttle is closed and the car should be using the Idle Air Control Valve exclusively for idle control. A fault TPS sensor can confuse the ECU causing the idle to be erratic or "hunting".
• High Idle Speed: The TPS may report faulty values causing the engine idle speed to be increased above normal. This is normally found in conjunction with a slow engine return to idle speed symptom.
• Slow engine return to idle: A failing TPS can report the minimum throttle position values incorrectly which can stop the engine entering idle mode when the throttle is closed. Normally when the throttle is closed the engine fuel injectors will be deactivated until a defined engine RPM speed is reached and the engine brought smoothly to idle speed. When failing a TPS will not report the throttle closed and fueling will continue causing the engine to return to idle very slowly.
• Engine Hesitation on Throttle Application: The TPS is also used by the ECU to determine if the driver has applied the throttle quicker than the Manifold Air Pressure sensor can read. The fueling is adjusted accordingly to cope with the sudden increase in air volume, however a faulty sensor can cause the ECU to ignore this data and the engine will "hesitate" when applying the throttle. In extreme cases with the engine at idle, a sudden application of full throttle can stall the engine.
• Engine Misfire: A fault TPS can report values outside the denied acceptable range causing the ECU to incorrectly fuel the engine. This is noticeable as a slight misfire and can trigger the misfire detection software and/or Malfunction Indicator Lamp (MIL) light on the dashboard. Extreme cases can cause excessing misfires resulting in one or more cylinders being shut down to prevent engine and catalytic converter damage.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #7 of 9 Old 11-20-2012, 07:48 PM Thread Starter
93fordguy
ok so i went out drove the jeep around for a wile till it came upto temp. put a fuel gauge on it and i was getting 30psi at an idle and like 25ish when i rev it. so m guessin i gotta do a pump and filter.
post #8 of 9 Old 11-20-2012, 11:44 PM
GetLifted
Sounds like it... good job! Let us know
post #9 of 9 Old 11-21-2012, 11:22 AM Thread Starter
93fordguy
well went out bought a new bosch pump and a filter for it sits right at 50 psi now and runs great. thatnk for all the help and info
