Quantcast 96 XJ - Puttering, looses power on acceleration - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > 96 XJ - Puttering, looses power on acceleration
Truck-Lite's New LED Headlamp SeriesTJ 5.25" Speaker Adapters - NalinMFGCURRIE TJ/LJ/XJ/MJ HD Steering - Low Price Guarantee!
Old 11-11-2004, 01:14 PM   #1
McCarley
Hey all,
My '96 XJ has started doing something strange. About a month ago the check engine light came on outa nowhere, but there was no noticable change to performance. The light went off about a day later. Since then it has done it one or two more times. But yesterday I was driving in the rain and made a right turn onto my street and got a total loss of power for a second (light came back on also). I noticed it immediatly and let up on the gas and then put it back down - no problem. But if I slam it down and let it up a few times - same problem. I also noticed the same loss of power a few times when first accelerating from a stop sign.
Should I check the CPU for errer code, if so where is it located and is there a list of the codes posted somewhere?
I'm open to ideas guys - whatya think it might be?
[FONT=arial black][B]'96_XJ_4.0L:HO_2WD_STOCKER[/B][/FONT]
McCarley is offline   Reply With Quote
Old 11-11-2004, 01:16 PM   #2
Jeep Cherokee
Sounds like the same prob that I have but I didnt get a check engine light. If you start it up cold does it start to sputter after about 5 min?
Red Jeep Club Member #16
Become a fan of the Jeep Cherokee XJ Facebook Page
Jeep Cherokee is offline   Reply With Quote
Old 11-11-2004, 01:19 PM   #3
McCarley
Nope. This all happened yesterday around 1pm. So I was interested to see what it would do this morning on a cold start - but no problem there. I did get a quick power loss though accelerating from a stop sign about a 1/4 mile from my house (first stop sign on the drive to work)
Old 11-11-2004, 01:24 PM   #4
McCarley
I can also add as a possible contributing factor that it has not had an oil change in quite some time.
Old 11-11-2004, 03:13 PM   #5
McCarley
I just took a drive for lunch and the check engine light was off, but still having the same power problem.
Old 11-11-2004, 10:00 PM   #6
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
What is the oil pressure reading at?
I would change the oil ASAP. Also, change the air filter! Could also be a O2 that's on it's way out.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Old 11-12-2004, 07:58 AM   #7
jandj
check the trouble codes. Do the key on and off thing. You should be able to find the codes somewhere or post what you found and someone will tell you what they are.
sold my 96' XJ
Look'n to purchase now
jandj is offline   Reply With Quote
Old 11-12-2004, 08:17 AM   #8
mbood82
Fuel pump/filter issues quite possibly...
'99 Jeep Cherokee - RE 3.5" SuperFlex with 32s
'06 Dodge Magnum R/T
'03 Toyota MR2 Spyder
mbood82 is offline   Reply With Quote
Old 11-12-2004, 11:33 AM   #9
McCarley
This morning it's running like crap! I'm on my way out to do the oil change right now and to check some other things too. Where is the CPU on my jeep?
Old 11-12-2004, 03:50 PM   #10
McCarley
Ok, I replaced the fuel filter, oil fitler, oil, air filter - and it looks like I'm in need of a new cap/rotor/wires combo too. Also, I hear at least one of my valves tapping pretty good. Havn't driven it yet to see if anything i've done up to this point has helped.
Old 11-12-2004, 05:50 PM   #11
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Run some Restore Engine flush through the motor before the next oil change. It's the mildest cleaner I have used and it have never messed with any of the seals. After that put in some fresh oil and see if the lifter noise is a little quieter.
Any oil on the air filter when you replaced it?
93 Sport
Specs in Profile.
Old 11-12-2004, 06:39 PM   #12
McCarley
No oil in the filter - oil presure is normal - I took it for a spin and it didn't sputter, but who knows if it will later or tomarrow. I havn't really gotten to "test" drive it the way I'd like to.
Old 11-12-2004, 08:03 PM   #13
93_zj
my '88 xj had a problem kinda like that,it'll start sputtering i let off the gas and step back on it,it gets a sudden burst of power,a couple of seconds later it starts sputterin' keeps doing it over and over,the emissions maintenance light is on,but of course,it's just on a timer so it's not like it really means much that the light's on,any suggestions?
93_zj is offline   Reply With Quote
Old 11-12-2004, 08:05 PM   #14
mbood82
Check the fuel filter yet?
Old 11-12-2004, 08:06 PM   #15
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
If the surging is just at start off I'd say pull the EGR vac line and plug it. If the problem goes away then replace the egr. If that doesn't cure it, clean the hell out of the TB, especially the IAC motor and housing.
93 Sport
Specs in Profile.
Glock Forum
