96 XJ Just installed RC 3" add a leaf Vibrations - JeepForum.com
post #1 of 7 Old 10-10-2012, 07:54 PM Thread Starter
RestoringDadsCJ
1946 CJ2A
Hey guys I have a 96 XJ Sport I just installed a 3" RC with lower control arms and real add a leafs. I had some decent vibrations around 35 to 50 especially when I let off the gas, So I dropped my TC 1" using Grade 8 washers stacked and welded together since the drop didnt come with the kit.
85% of the total vibration is now gone, and when I let off the gas the vibration has gone but theres still some vibration around the 35 to 50mph mark, but more so around 65 now.
The front drive shaft is the double cardan style, and the front U joint has been replaced by me, I had no idea how to change to 2 on the other end so left them be. But appear to be in good shape, no slop or anything.
The rear drive shaft has to rubber boot on it going into the Transfer case,not sure the name of that style of drive shaft but none of those U joints have been replaced. Appear to be in good working order.
Im running a new set of Cooper STT's 31 x10.5 x15's on stock steel Jeep wheels.
And I havent had a front end alighnment since the tires or the lift kit, was trying to wait till I replace the track bar and other steering components with heavy duty gear.
So any ideas would be of great help guys
RestoringDadsCJ is offline
post #2 of 7 Old 10-10-2012, 08:01 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Either you have a worn u-joint, or your pinion angles are off and need adjusting. Start with some fresh u-joints, they are cheap and relatively easy to install.
CJ7-Tim is offline
post #3 of 7 Old 10-10-2012, 08:18 PM Thread Starter
RestoringDadsCJ
1946 CJ2A
Copy that. I was wondering if there were some type of shims I could put on the back axle? If so any particular degree?
post #4 of 7 Old 10-10-2012, 08:26 PM
CJ7-Tim
CJ7-Tim's Avatar
That is the pinion angle checking/adjusting part. Shims are possibly needed.
Start with fresh u-joints, often a new lift will stress a weak u-joint, and vibes will show up.
CJ7-Tim is offline
post #5 of 7 Old 10-10-2012, 11:17 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
I've got 3.5" And 1" dogleg shackles in the rear. I have the same problem but mine is caused by a tire that is too irregularly worn to be balanced.
D3<!L!>3D
S8NNG8 is online now
post #6 of 7 Old 10-11-2012, 01:19 PM
jeepnphreak
1989 XJ Cherokee
And after all of mentioned above and you still have vibrations, you may need to consider a SYE.
1989 XJ, 5spd, np231 with bjconversion SYE , re3.5, 33x12.5r15 BFgoodrich ATS, D30 F, Dana 44 from 87 with 4.56s, Custom front bumper.
94 yj: stock everything and 4 angry squarrels under the hood.
jeepnphreak is offline
post #7 of 7 Old 10-13-2012, 09:04 PM Thread Starter
RestoringDadsCJ
1946 CJ2A
Welp
Welp guys, I removed the rear driveshaft to replace the ujoints, but first I took it out for a quick drive, and since the drive shaft was gone all the vibrations were gone, so at least I found the issue. I replaced the UJoints and reinstalled the drive shaft and it feels better but now the vibrations are around 25 to 27mph and 65mph. What next?
