96 xj ho 6 4x4 starting problems - JeepForum.com
post #1 of 2 Old 05-29-2014, 10:16 PM Thread Starter
cchambless13
So here goes, key ignition switch snapped I had to hot wire it to get it home, then my gf had to drive to work next thing I know it's 4 months later before I break down and get the key switch problem is it was too late, I f ed it up by hard wiring it for so long. I got the new key In , guess what no start had burnt wires under the steering column fixed those, got voltage to all the things that need the voltage starter ASD ect , I checked coil replaced it bc low voltage was read, I got voltage, put it into the cap did t get it out replaced w new button and cap, still nothing. New battery to be sure still now no spark, I've read all the forums I think on this ASD, CPA, ECt I'm looking at a new distributor now. I've tried the alarm trick resetting the ecu, disconnecting and resetting the CPs, is there anything else that I'm missing ??? It's driving me nuts. I've checked tps, CPA, timing, rotor button moving, starter, 5volt reference on all the sensors so I think computer is still good, is there an easy way to test the ecu? I even loosened the screws to make sure they were the 1/4" screws not the 1/2" screws that sometimes cause issues.
So my to do list:
All new ASD style relays
Camshaft position sensor/stator/gen replacement
Check alternator( jic) for gen light
Crankshaft position sensor replacement
Computer
My ASD relay is clicking and fuel pump clicks w it along w all fuel Injectors
I'd say about every 3 seconds they click over and over again as if they r all resetting over and over again.
Let me know if anyone can help me please I'm n the charleston area and tight on funds
cchambless13 is offline
post #2 of 2 Old 05-29-2014, 10:56 PM Thread Starter
cchambless13
Ok my gf just found something ! The camshaft position sensor after key on sends a signal to the e c u then goes to the ASD relay causing clicking if there is low voltage. That in turn will keep everything from working the crankshaft fuel Injectors spark fuel pump etc . So next on my list is the pickup that goes in the distributor. I looked at mine a few hours before and with the jeep having 207k miles on it it is worn down pretty bad. So that's next on the todo list and of course ASD relay lol. Thanks guys hopes this helps everybody
asd , cps , distributor , ignition
