96 XJ build "Hybrid" - Page 4 - JeepForum.com
post #46 of 103 Old 09-11-2012, 01:13 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Very nice axle swap! Looks really good and very stout.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #47 of 103 Old 09-11-2012, 01:16 PM
NW99XJ
Nicely done!!!
5+" of lift, 33's, OTK, Armored, Lighted, Chipped, Winched & Locked up Front.
NW99XJ is offline
post #48 of 103 Old 09-11-2012, 04:07 PM Thread Starter
DoctorTim
thanks!
I got myself a matching front end as well. recently rebuilt great condition, but after a few days my wheel hubs are going bad. time to order timken hubs!
where can i get a nice A/T 33" tire for cheap? anyone know? discounttire has BFGs for a decent price but i dont like the look of those, also heard they bruise too easily.
96 XJ, geared, 8.8, 5", 33s, dash
DoctorTim is offline
post #49 of 103 Old 09-11-2012, 05:13 PM
Diamond-x
1991 XJ Cherokee
Your 8.8 install looks great! Where did you source your axle? I'm in Pomona and have been looking for some time with no luck.
Diamond-x is offline
post #50 of 103 Old 09-11-2012, 06:16 PM Thread Starter
DoctorTim
pickyourpart.com
every location has a list of vehicles they recently put out on the lot, just wait until they throw an explorer out there. I was lucky with mine, got the most desirable version of the 8.8. they will have a lot of 8.8s with lower (numerically) gear ratios and many of them have open diffs. the 4.10 LSD with disks is harder to find than the others.
post #51 of 103 Old 09-12-2012, 02:19 PM Thread Starter
DoctorTim
post #52 of 103 Old 09-12-2012, 05:32 PM
Diamond-x
1991 XJ Cherokee
Originally Posted by XJ-Tim View Post
pickyourpart.com
Thanks for the info, build look great!
post #53 of 103 Old 09-12-2012, 06:33 PM
Fargo5757
back to the hood vents...
do you have any plates directing the water flow that makes it through the vents or does it just drip onto the engine?
Fargo5757 is offline
post #54 of 103 Old 09-12-2012, 06:34 PM
Fargo5757
post #55 of 103 Old 09-12-2012, 06:41 PM Thread Starter
DoctorTim
i didnt put anything to direct water away from the motor, not much water gets through the vents, more water finds it way from beneath than it does from the vents.
post #56 of 103 Old 09-13-2012, 10:57 AM
Diamond-x
1991 XJ Cherokee
XJ-Tim,
Sorry to keep rehashing this: When you got your axle, did they pull it for you or did you have to take it off the wreck and wrestle it to your car?
Thanks!
post #57 of 103 Old 09-13-2012, 11:58 AM Thread Starter
DoctorTim
XJ-Tim,
Thanks!
you gotta pull it out yourself, they let you use little carts so you can haul it around, but thats all they help you out with. i suggest cutting some seat belts out of another car in the JY so you can hoist it easier, also helps to have someone help you out with all of this.
post #58 of 103 Old 09-13-2012, 04:40 PM
DezertXj88
1990 XJ Cherokee
A 8.8 isn't tooo heavy honestly! Once you have it dropped you can get it out and onto a wheel barrel as long as you can carry 250lbs or so. If not then bring a friend or ask someone around? Most are usually willing to help!
But please, please Tim entertain us with more pics & directions on that dash?
DezertXj88 is offline
post #59 of 103 Old 09-13-2012, 10:28 PM Thread Starter
DoctorTim
I did all the design, fabrication, and paint. The only thing I didn't do was the CNC plasma cutting which was done at a local shop. All stock switches were ripped out and the wire harness was modified so I could use my own switches for everything. This included 100+ feet of wiring, 8 relays, $150 in switches and indicator lights, countless blown fuses, and a lot of patience.
For me, a project like this isn't difficult, it's just very time consuming and somewhat costly, so I would prefer nobody ask me to make one for them, as I will feel bad saying NO.
Anyone with the tools, research, resources, and mental stability can do this project. Believe me when stuff isn't going the way you want it to, you start kicking and throwing things, and then regretting it.
here are some pics of the fabrication process, enjoy.
post #60 of 103 Old 09-14-2012, 04:48 AM
DezertXj88
1990 XJ Cherokee
Freaking sick job...however are you going to start producing some bumpers? Maybe side projects
cademan04's 97 xj, "safari wagon" build thread cademan04 XJ Cherokee Technical Forum 73 01-29-2014 01:33 AM
Scooty Puff Senior, "The Doom Bringer" build thread. jeepdavetj XJ/MJ Cherokee Non-Technical Forum 7 09-06-2011 03:11 PM
Putting together 4.5" hybrid lift, have question.. xjfan XJ Cherokee Technical Forum 0 11-04-2009 11:21 AM
running the DPG/RE hybrid 5" with 36s? can it be done? Magic2979 XJ Cherokee Technical Forum 17 07-07-2005 02:42 PM
RE 5.5 Extreme Duty vs DPG 5" hybrid kit Magic2979 XJ Cherokee Technical Forum 20 06-26-2005 03:15 PM
