96 XJ build "Hybrid" - Page 3 - JeepForum.com
post #31 of 103 Old 03-01-2012, 09:57 AM
NW99XJ
H'n'T SYE?
(I went thru a nightmare doing mine......)
If you can.... split your case, remove your main shaft and do it on a lathe..... it's FAR easier in the long run.
(see my build thread...I documented the whole process)
5+" of lift, 33's, OTK, Armored, Lighted, Chipped, Winched & Locked up Front.
NW99XJ is offline
post #32 of 103 Old 05-08-2012, 07:41 PM Thread Starter
DoctorTim
Originally Posted by NW99XJ View Post
H'n'T SYE?
just did my SYE and it was not very hard with the TC still in the jeep. all i did was put it in drive and let it idle so the output shaft spins and then use a cutoff wheel. It cut really clean as if i did it on a lathe (not really but close enough). drilling and tapping the center mounting hole was easy.
also installed some degree shims to correct the pinion angle on the rear diff.
96 XJ, geared, 8.8, 5", 33s, dash
DoctorTim is offline
post #33 of 103 Old 05-08-2012, 07:45 PM Thread Starter
DoctorTim
an update. got some work done over the past few weeks.
DIY links (not quick disconnect YET but i should be getting the needed hardware soon)
roof rack
post #34 of 103 Old 05-08-2012, 07:53 PM Thread Starter
DoctorTim
also
post #35 of 103 Old 05-08-2012, 08:39 PM
chiefbill1959
Nice write up. I'll be keeping an eye on your progress and perhaps using some of your ideas. OK, I'll be stealing them OK, I said it. LOL. Keeps us posted.
96 XJ, 3 in. Rustys full pack lift, 4.0, AW4, D35, C8.25
86 XJ, 3 in. RC, bb rear pack, 3.4 L engine
chiefbill1959 is offline
post #36 of 103 Old 05-09-2012, 03:42 PM
Azzy
Originally Posted by XJ-Tim View Post
also
I was thinking the same thing!!! Only out front, but I like that better What pieces did you end up doing?
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #37 of 103 Old 05-09-2012, 05:14 PM Thread Starter
DoctorTim
i think its 3". one 90* and a 45* elbow. used RTV to seal it.
EDIT: actually those two elbows are different diameters. i just mixed and matched at home depot until i found a nice combo.
post #38 of 103 Old 05-11-2012, 03:34 PM
Azzy
Nice! Im yoinking that one. Just sealed up the front with rtv and a plug?
Azzy is offline
post #39 of 103 Old 05-11-2012, 04:13 PM Thread Starter
DoctorTim
yup. good luck.
post #40 of 103 Old 06-04-2012, 05:28 PM Thread Starter
DoctorTim
A while back i found a ZJ in the junkyard with racing seats. one of the seats was ripped up, the other one was in decent shape so I took it. It sat in my garage for a while, then I got this brilliant idea.
also, the sway bar link brackets I made were too weak, so I made better ones with thicker metal and a better welder.
post #41 of 103 Old 06-12-2012, 06:58 PM Thread Starter
DoctorTim
getting ready to get an 8.8!
post #42 of 103 Old 09-10-2012, 12:31 PM Thread Starter
DoctorTim
8.8 time!!!!! 41:10 gears, LSD, disks.
post #43 of 103 Old 09-10-2012, 12:57 PM Thread Starter
DoctorTim
post #44 of 103 Old 09-10-2012, 01:49 PM
cbenez1
Nice work. Best mod I've done so far was the 8.8 swap in mine.
A nation that forgets it's defenders will itself be forgotten
01 Up Country 6.5 long arm
cbenez1 is offline
post #45 of 103 Old 09-11-2012, 02:04 PM Thread Starter
DoctorTim
yeah this thing has so much more power at the wheels. 4.10 gears are great. i can finally start looking at 33" tires!
cademan04's 97 xj, "safari wagon" build thread cademan04 XJ Cherokee Technical Forum 73 01-29-2014 02:33 AM
Scooty Puff Senior, "The Doom Bringer" build thread. jeepdavetj XJ/MJ Cherokee Non-Technical Forum 7 09-06-2011 04:11 PM
Putting together 4.5" hybrid lift, have question.. xjfan XJ Cherokee Technical Forum 0 11-04-2009 12:21 PM
running the DPG/RE hybrid 5" with 36s? can it be done? Magic2979 XJ Cherokee Technical Forum 17 07-07-2005 03:42 PM
RE 5.5 Extreme Duty vs DPG 5" hybrid kit Magic2979 XJ Cherokee Technical Forum 20 06-26-2005 04:15 PM
