'96 Coolant Temperature sender for a '99 4.0 - JeepForum.com
post #1 of 7 Old 11-07-2008, 01:57 PM Thread Starter
crash9686
Hello all, this is my first time asking a question and i hope some one will be able to help me. I recently put a '99 4.0 into my '96 XJ every thing changed over just fine except for the coolant temperature sending unit. I know on the pre-'97 4.0's the CTS is in the cylinder head but not on the later models which the gauge info is sent through the BCM. So I'm wondering if anyone knows where the single wire from the back of the head can be moved to so my gauge will work. All suggestions will be greatly appretiated.
crash9686 is offline
post #2 of 7 Old 07-10-2013, 01:26 PM
QuadRaider1
I'm in the same boat. My daughter roasted the head in our '96 Cherokee. I found a pristine replacement from a '98 at the salvage yard, but didn't notice it didn't have a tapped hole for the CTS until I'd already installed it on my '96. Looks like I could drill and tap the '98 head, but is there an easier way?
QuadRaider1 is offline
post #3 of 7 Old 07-10-2013, 09:12 PM
djb383
Copper tubing nipple mounted in the 3/4" heater hose (close) to the t-stat cover with a brass bushing that has the same internal thread as the sending unit and all JBWelded or soldered up. sending unit wire will need to be extended to reach front of motor.
Uploaded with ImageShack.us
Man Law - hoods should be raised at least once a week.....have a look see.
djb383 is offline
post #4 of 7 Old 07-11-2013, 07:41 AM
QuadRaider1
That's awesome. Thanks for sharing.
post #5 of 7 Old 07-17-2013, 12:05 PM
QuadRaider1
I built the same kind of set up, but I'm still getting the Check Engine light, my temp gauge is still not working and the electric fan is not coming on. Is there another sensor I've missed or a plug I didn't re-attach?
post #6 of 7 Old 07-17-2013, 01:39 PM
gs69350
Those fittings will need to be grounded to the engine block as well.
1998 Jeep Grand Cherokee 5.9 Limited - Stone White - Stock for now.
<-- 5.9 Owner's group on FB.
gs69350 is offline
post #7 of 7 Old 07-17-2013, 01:41 PM
QuadRaider1
Ah, I thought that might be the issue. Thanks for all your help.
coolant temp. sensor/sender issues levenbad1588 XJ Cherokee Technical Forum 2 03-10-2009 01:12 PM
no coolant temp sender on the back of the head? sbs10v8 XJ Cherokee Technical Forum 17 07-05-2008 09:34 PM
coolant temperature dirtdad XJ Cherokee Technical Forum 10 02-27-2008 09:36 AM
coolant temp sender for gauge cluster 87baseomatic XJ Cherokee Technical Forum 4 12-28-2005 07:22 AM
Coolant temp sender cmotsvt XJ Cherokee Technical Forum 0 05-13-2005 08:28 PM
