96 cherokee starting issues running errands - Page 2 - JeepForum.com
post #16 of 25 Old 08-05-2013, 05:50 PM Thread Starter
Unclebrixxy
Thanks
Unclebrixxy is offline
post #17 of 25 Old 08-26-2013, 05:44 AM Thread Starter
Unclebrixxy
Finally replaced the cps. Hopefully that does the trick
post #18 of 25 Old 08-26-2013, 06:04 AM
bigbill888
Originally Posted by Holder350 View Post
What is "won't start"? Won't turn over or won't catch?
Sent from my phone
What is catch?
96 ZJ Laredo, 4.0, 242, 230K
95 ZJ Limited, 4.0, 242, 140K
98 XJ Sport, 4.0, 231, 140K
All work well
bigbill888 is offline
post #19 of 25 Old 08-26-2013, 06:22 AM
Holder350
1995 XJ Cherokee
Originally Posted by bigbill888 View Post
What is catch?
Engine will either turn over and not try to run or a cylinder will hit every so often but not enough to get the motor running.
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #20 of 25 Old 08-26-2013, 08:48 AM
HobbesMRH
I've seen a problem like this before. In that case the solution was just to clean and regrease the NSS. Before that the Jeep could be coerced into starting by fiddling with the shifter a bit.
HobbesMRH is offline
post #21 of 25 Old 08-26-2013, 03:03 PM
Holder350
1995 XJ Cherokee
Originally Posted by HobbesMRH View Post
I've seen a problem like this before. In that case the solution was just to clean and regrease the CPS. Before that the Jeep could be coerced into starting by fiddling with the shifter a bit.
I believe you mean NSS not the CPS
post #22 of 25 Old 08-26-2013, 04:22 PM Thread Starter
Unclebrixxy
Crankshaft sensor
post #23 of 25 Old 08-26-2013, 04:28 PM Thread Starter
Unclebrixxy
If I did a lot of stop and starting in a short period it would turn over but not catch once it got hot. Also conked out a couple times when sitting at a dead stop for a Long period. Is starting much better now and haven't problems since the fix but I haven't driven that much the last week
post #24 of 25 Old 08-27-2013, 08:38 AM
HobbesMRH
Edited my OP, thanks for catching that.
post #25 of 25 Old 08-27-2013, 08:40 AM
HobbesMRH
I believe it was with the CPS that I had some luck unplugging, and plugging it back in again to get the Jeep started a couple times.
