'96 Cherokee Sport parking brake question... - JeepForum.com
post #1 of 4 Old 08-15-2002, 12:47 PM Thread Starter
White-Knight
Hello all,
I've got a quick question. For whatever reason, the parking brake on my '96 Cherokee Sport is having problems with the indicator light. Sometimes when I engage the parking brake, the light will go on (the 'Brake' light on the dash console) and sometimes it will not. It follows no set pattern. I know that the parking brake works because I can hear it engage if I have the engine off and the door open and I can hear it disengage as well. Today, I took apart the dash and checked the bulb and all is fine there. Any ideas? Can there be some sort of intermittent shorted wire somewhere? If so, any ideas where to look? Thanks in advance.
White-Knight is offline
post #2 of 4 Old 08-16-2002, 08:26 AM
williak
Wink
If the parking brake wire is "shorting out", your light would come on intermittantly while the brake is off. Check your switch at the brake handle to make shure the contacts close and the electrical connections to it. A bad switch or bad connection will give you an intermittant light with the brake on.
williak is offline
post #3 of 4 Old 08-16-2002, 10:22 AM Thread Starter
White-Knight
Well, the light only comes on sometimes while the brake is engaged - never when it's off, so perhaps it's the switch at the brake end then? Thanks for the help. Is there any easy way to get into there (the parking brake housing), or do I have to dismantle the whole center console?
post #4 of 4 Old 08-17-2002, 09:59 AM
williak
Red face
Sorry to say it, but yes. But while you are there you can check every thing elese out, then you won't have to do it again soon.
williak is offline
Cherokee Parking Brake Button Problems! Floridafan54 XJ Cherokee Technical Forum 1 02-24-2009 09:12 AM
parking brake question vicegod2003 XJ Cherokee Technical Forum 3 02-06-2008 11:00 AM
Parking brake question summitlt XJ Cherokee Technical Forum 1 05-31-2005 08:13 PM
Parking brake question... leadfootny XJ Cherokee Technical Forum 0 04-18-2005 09:30 AM
'98 Sport Parking Brake problem MurphoAZ XJ Cherokee Technical Forum 1 09-02-2004 01:38 PM
