96 Cherokee Sport - Fuel Issues - JeepForum.com
post #1 of 2 Old 11-17-2011, 05:26 PM Thread Starter
Arsenal101
1996 FSJ Cherokee
I have a 96 Cherokee Sport, 5 speed 4 wheel drive 2 door with the 4.0 straight 6 with 205,000 miles, and lately its been acting like an injector was stuck open. When it warms up it would have a really rough idle and alot of black smoke was comming out of the tail pipe. but the fuel pressure was good. I have tried running SeaFoamŪ though it and a fuel injector cleaner through the tank. Just the other day it set off a check Engine light for a P0171 code, system running to lean. I think it may be a dirty MAP sensor? or maybe a shorting out upstream 02 sensor? just looking for some other oppinions so i dont go replacing all injectors and have it not be the case.
Arsenal101 is offline
post #2 of 2 Old 11-17-2011, 05:59 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The most common causes would be a failing O2 sensor, or a leaky exhaust manifold.
If the O2 sensor is the original, replace it. Check the exhaust manifold for cracks, if cracked, replace it. Cracked manifolds are very common.
P0171 JEEP - Fuel System 1/1 Lean
Symptoms
- Check Engine Light ON
- Excessive Fuel Consumption
Possible causes
- Intake air leaks
- Faulty front heated oxygen sensor
- Ignition misfiring
- Faulty fuel injectors
- Exhaust gas leaks
- Incorrect fuel pressure
- Lack of fuel
- Faulty (MAP) sensor
CJ7-Tim is offline
1996 , 5 speed , cherokee , injector leak , sport
97 Jeep Cherokee Sport Issues dtreed1 XJ Cherokee Technical Forum 6 12-19-2013 11:57 PM
1999 Cherokee Sport Horn issues??? shelby_Extreme XJ Cherokee Technical Forum 2 02-04-2010 06:37 PM
2001 Jeep Cherokee Sport AC issues... Squid78 XJ Cherokee Technical Forum 6 07-24-2009 08:47 PM
Just bought a 93 cherokee sport 2dr, some issues. black-z XJ Cherokee Technical Forum 2 06-06-2009 05:41 AM
Electrical Issues - 99 Cherokee Sport blf XJ Cherokee Technical Forum 6 05-26-2007 03:50 AM
