96, Cherokee sport. cranks but wont start. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > 96, Cherokee sport. cranks but wont start.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire CarrierBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 08-09-2014, 02:10 PM   #1
wilding592
1996 TJ Wrangler
simply put, when the key is turned the girl will crank but just wont start. iv got power, i can hear the fuel pump starting, iv replaced the ignition coil and the crank position sensor. and i still dont get a spark, and last iv hooked up a coder and it keeps saying no codes available.
wilding592 is offline   Reply With Quote Quick reply to this message
Unread 08-09-2014, 02:49 PM   #2
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Have you checked the 30a mini fuse in the PDC? blowing fuses and can't figure out why
***Chris***
JeepForum.com/IndyORV@Redbird-SRA
COTY 2009
chris87xj is online now   Reply With Quote Quick reply to this message
Unread 08-11-2014, 06:37 PM   #3
wilding592
1996 TJ Wrangler
I'v tested all the fuses and they seem to be fine.
Unread 08-11-2014, 07:17 PM   #4
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
At the risk of being redundant but just to be sure , you've verified or changed out this 30 amp fuse?
***Chris***
COTY 2009
Unread 08-13-2014, 08:03 PM   #5
wilding592
1996 TJ Wrangler
it was a good thing you were insistent because i managed to over look those when i tested the fuses, and yest the 30 was blown, i just got done with it and i replaced it twice and it kept popping, any ideas?
Unread 08-13-2014, 08:41 PM   #6
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
That fuse supplies power to the coil - as well as the O2 sensors. O2 sensors often short out at end of life. It takes a while for a bad O2 sensor to generate a CEL. A good rule of thumb is to replace them every 60k miles.
I would unplug both O2 sensors and replace the fuse then see if she'll run like that. If so it's a pretty good indication of a bad sensor, and if that's the case, you could plug them back in one at a time to see which is shorted or just replace both and be good to go for another 60k.
***Chris***
COTY 2009
Unread 08-14-2014, 02:37 AM   #7
JeepinInJackson
1989 XJ Cherokee
I like Chris' idea of unplugging o2 sensors to test it out before buying new ones. Also check your camshaft positioning sensor as seeing how they give ppl a lot of grief in the xjs so I've heard. By the way just because fuel pump is making noise doesn't mean it's putting out proper fuel pressure so I recommend borrowing a fuel pressure gauge if you don't have one and hooking it up to see what it says. Seen a thread a guy posted yesterday or something where his wouldn't crank and his pump wasn't that old and it was making noise but when he replaced it problem was fixed as well as he said it felt more powerful, hope this helps!
JeepinInJackson is offline   Reply With Quote Quick reply to this message
Unread 08-18-2014, 08:14 PM   #8
wilding592
1996 TJ Wrangler
there is no camshaft sensor. and i unplugged the o2 sensors and it started and ran for about 3 seconds then died while trying to give it gas, then i tried to start it and it keeps popping fuses
Unread 08-18-2014, 08:33 PM   #9
lzugl
Mine did this to me a while back on my 90 cherokee.. If its cranking and not starting that should tell you your starter is fine. try to jump it, if it still just cranks that means you're not getting enough spark. Check your plugs along with your cap n rotor.
Mine was cap n rotor. i changed that out and it fired right up..
lzugl is offline   Reply With Quote Quick reply to this message
Unread 08-18-2014, 09:23 PM   #10
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Something fed by that fuse is shorted out.
Here's what I'm thinking it feeds.
***Chris***
COTY 2009
Unread 08-20-2014, 11:14 AM   #11
1stockjeep
1993 XJ Cherokee
Try unplugging the coil and crank it for a bit, the fuse also feeds that so it could be the issue, obviously it won't start tho lol. Pull fuel
Pump relay to prevent fouling plugs and washing cylinders
1stockjeep is offline   Reply With Quote Quick reply to this message
Unread 08-25-2014, 01:49 AM   #12
wilding592
1996 TJ Wrangler
sorry about taking so long to reply iv been out of town for work, finally I fixed my ol jeep. The problem was the distributor cap, once I replaced that everything went fine! thank you everyone!
Unread 10-26-2014, 04:56 PM   #13
wilding592
1996 TJ Wrangler
Im back guys... so i had the same problem again this week, [crank but no start and keeps popping that lil 30a fuse, and im really stumped with what it could be, so far iv replaced the the plugs, cap n rotor and the ignition coil and nothings helped. any advise?
Unread 10-27-2014, 01:28 AM   #14
BagusJeep
BagusJeep's Avatar
1981 CJ7
It was not your distributor cap. That was just a coincidence.
if you look at the diagram that circuit goes to the coil, o2 sensors and the back of the generator. Have you checked the wire going out to the generator? Have you tried unplugging it and has this got any effect on the fuses blowing?
BagusJeep lives in Bali, the Land of Temples.
With a Jeep every prayer counts.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline   Reply With Quote Quick reply to this message
Unread 11-03-2014, 03:13 PM   #15
wilding592
1996 TJ Wrangler
i unplugged the genny and the fuse is still popping
