96 cherokee sport - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > 96 cherokee sport
Only 2 Days left to win $3,800 Jeep Parts!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAttention seahawks fans!!! Want to save some $$$ ??!!
Unread 02-09-2014, 06:48 PM   #1
pointdexter-xj
96 cherokee sport
Hay guys
So i own a 96 cherokee sport my 1st jeep evere and wow what a beast it is i love it the shape the performance its perfect!
So i havent had much problems with it other then a split lower radiator hose that i had to rrplace but now i notice it needs a good flush but cant find the drain tap Can anyone help?? And would it be easyer and cheaper in the long run just to replace the radiator. By the way my xj is right hand drive as im from nz
pointdexter-xj is offline   Reply With Quote Quick reply to this message
Unread 02-09-2014, 07:21 PM   #2
00XJMikey
Originally Posted by pointdexter-xj View Post
Hay guys
Give this a read: http://www.jeep4x4center.com/blog/?p=2308
[URL="http://m.facebook.com/?_rdr#!/michael.rose124"]Facebook[/URL]
00XJMikey is offline   Reply With Quote Quick reply to this message
Unread 02-09-2014, 07:47 PM   #3
tjwalker
It's the crank sensor!
tjwalker's Avatar
I highly suggest you drop the lower radiator hose to drain the coolant. The petcock to drain from the radiator on the XJs is woefully under-designed and has a history of breaking. I won't use them.
Just be careful when you drop the hose as it will come out swiftly. Wear eye protection and have a big drain pan!
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline   Reply With Quote Quick reply to this message
Unread 02-09-2014, 09:43 PM   #4
pointdexter-xj
@00xjmikey
Thanks alot mate that link was awesone explain everything perfect. Just what i was looking for thats a big help
Cheers mate
Jeeplife
