96 Cherokee rough idle lacks power. 4.0 engine. - JeepForum.com
post #1 of 8 Old 12-13-2008, 10:28 AM Thread Starter
johnspinner
I need help figuring out what to do next to get my engine running right.
My 1996 Jeep Cherokee Country with 4.0 engine has a rough idle and lack of power. I get engine missfire codes in cylinders #1 and #2, and sometimes #3. The engine has 150,000 miles and no major engine work has ever been done on it. It does not accelerate smoothly. It started several months ago with only a rough idle and now it has progressed to missfiring during acceleration.
Here is what I have done so far:
Replaced the spark plugs twice (Autolite the first time, OEM Champion the second time). Gapped them both times at 0.035.
The second time I replaced the spark plugs (after 1,000 miles) I looked at the removed plugs and the color on all 6 plugs looked a light tan. The insulator was still white. Other than the electrodes being a light tan they still looked new.
Replaced plug wires, rotor, and distributor cap.
Replaced fuel filter.
Replaced Throttle Position Sensor and Idle Air Control valve.
Removed the throttle body and cleaned every nook and cranny.
Checked fuel pressure at the fuel rail. 38-40psi with engine running. drops about 2 psi when throttled to 2500rpm. When I first turn the key on with no pressure the gauge moves to about 25-30psi. It takes a second turn of the key to get it to 40psi. I'm not sure if that is normal. I did a bleed down test and the pressure dropped about 15psi in 5 minutes.
I checked all six cylinders for compression:
#1 - 140
#2 - 130
#3 - 145
#4 - 152
#5 - 148
#6 - 150
I replaced all 6 injectors with brand new OEM injectors.
The engine still idles rough, gets missfire codes in #1, and #2, and lacks power when accelerating.
I know the fuel pressure is a little lower than spec's. I am hesitant to replace the fuel pump assemble (it also contains the regulator) because the missfire codes are for only two cylinders. Maybe someone out there has experience with fuel pumps and can tell me if this could be an issue.
Can anyone help?
johnspinner is offline
post #2 of 8 Old 12-13-2008, 10:30 AM Thread Starter
johnspinner
Correction to miles on 96 Cherokee
The engine has 250,000 miles, not 150,000 as in my previous post.
post #3 of 8 Old 12-13-2008, 03:56 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
My first gut instinct is that you have a vacuum leak somewhere, possibly in the intake manifold?? I've seen where a leak there can be responsible for random cylinder misfires.
I tend to think you have a "common" hardware cause like this, rather than coincidentally having something wrong with the hardware on 3 of your cylinders at the same time. You've pretty much ruled that out anyways by replacing plugs/wires/cap/rotor and testing compression.
If it were mine, I would start by doing some vacuum testing and if that didn't show anything, possibly an engine analyzer may help. You can tell a lot about how an engine is running by testing vauum.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #4 of 8 Old 12-29-2008, 08:35 AM Thread Starter
johnspinner
Just replaced the fuel pump and MAP sensor. Got my power back. No longer lacks power when accelerating. Checked vacuum and no leaks. Still runs rough and missfires at idle. Engine codes indicate all cylinders are missfiring. I don't have any garages around here I can trust not to rip me off. Anyone know what else I should look at?
post #5 of 8 Old 12-29-2008, 09:09 AM
compfreak530
i would get a can of staring fluid and start the jeep, while running lightly spray the starting fluid around were the intake manifold connects to the block up and down it. if the idle increases at all while doing this. the gasket may need to be either tightened or replaced also i would try disconnecting the vaccum canister from the intake, see if it improves at all, also try spraying the starting fluid around hoses that look bad, good luck
compfreak530 is offline
post #6 of 8 Old 03-10-2015, 06:08 AM
davidsimpson
@johnspinner
I have the same problem, same year and the jeep country. Wondering if you ever solved the problem and, if so was it the manifolds. Thanks for all the great info in the forum. Please, Please, Please reply back. Thank you.
davidsimpson is offline
post #7 of 8 Old 03-10-2015, 06:52 AM
mustang_gt_350
I know this is old, but since you have a 96 I'm going to comment and also ask for help.
What all have you checked on your jeep? I would check the plugs/wires,coil, and for intake leaks.
Now on a note to try to help my problem. Is there anyway you can see where some wire connectors go for me? I'm in the middle of an engine swap into a 96 (99 engine trans,tcase) and am having some issues.
The link below will show you the LOCATION of the harness i'm talking about is on the jeep. Its just off center on the passenger side of the firewall. The pic is from the 99, The 96 will have 4 plugs of about the same size instead of the 2 small and 1 large. I need to know where the 2 small ones go, I know 2 of them go to the Trans but no idea where the other 2 are to go.
I would have sent a PM but i couldn't find the option, i guess i don't have enough posts to do so.
http://postimg.org/image/uq7e0taxh/
mustang_gt_350 is offline
post #8 of 8 Old 03-10-2015, 11:52 AM
mustang_gt_350
Found mine. The extra 2 must run to the Tcase, and the rear O2. I looked at a standard trans XJ and it only had 2 plugs 1 went to the Tcase, the other the rear o2
Rough idle, loss of power on acceleration…..but only sometimes. firedoghfd XJ Cherokee Technical Forum 8 12-05-2013 11:49 PM
Rough idle help after engine install... medicbear XJ Cherokee Technical Forum 8 08-24-2008 02:07 AM
Rough Idle on '99 Cherokee--TPS XJER XJ Cherokee Technical Forum 7 10-02-2007 09:19 PM
00 XJ Rough idle and no power? GuitarJer XJ Cherokee Technical Forum 2 08-16-2007 08:32 PM
Rough idle and power loss JEEPAUL XJ Cherokee Technical Forum 0 02-20-2007 01:25 PM
