96 Cherokee odd turn signal problem. - JeepForum.com
post #1 of 6 Old 05-27-2012, 08:20 PM Thread Starter
comanche17
1996 FSJ Cherokee
I just bought a 96 Cherokee and it has a weird problem. first off, the headlights wont turn on. so i checked it out and turns out i had power doing to the ground wire? so i grounded it and now the headlights work. so i fixed that problem but that's just the start.
when your in the truck and you turn on the left turn signal and look at the dash both right and left turn signal lights on the dash turn on. but when you get out of the truck and look only the left side marker is flashing but the turn signal underneath the headlight doesn't do anything. and the right side does nothing as it should.
when you turn on the right it does the same thing on the trucks dash but when you get out the right side marker works but the turn signal underneath the right headlight doesn't work. just like the left. the left does nothing like it should.
at night when you have the headlights on, when you try to turn on a turn signal the hazards come and and it blinks slow but then it speeds up really quick. the turn signal lights underneath the headlights don't come on ever.
im not sure what could be wrong? the rear lights are fine. except when you have the headlights on. the the hazards come on when you turn on a turn signal.
I think it might be the gauge cluster. the odometer is frozen solid and that's where both the lights come on at once.
Idk what do you guys think i should do or where should i start looking?
comanche17 is offline
post #2 of 6 Old 05-27-2012, 08:27 PM
n5xl
Just a hunch but at a minimum, you've likely got a grounding problem at one or more of the outside turnsignals. Try removing the lenses and removing the bulbs at each corner and leaving the sockets hanging with no bulbs in them...my guess is you'll see the problem immediately as corrosion in the bulb socket. Turn on a turn signal and try putting a bulb in that side and see if it works. If its not flashing, start look at the ground wire for that light. IFix the turnsignals before you try tackling all the other stuff that might be wrong. Keep it simple and work on problems you can get to easily first. You just might get lucky and solve some of the other problems with correcting the turn signals.
99TJ,AX15,2"ACOS,33BFGKM2
99XJ,AW4,2"OME,JKSShortArms
98XJ,AW4,3"ACOS/Shackles/AASYE/TomWoodsDS
n5xl is offline
post #3 of 6 Old 05-29-2012, 04:20 PM Thread Starter
comanche17
1996 FSJ Cherokee
ok ill try that. hopefully that will fix it. if not the next step will be replacing the gauge cluster. thanks
post #4 of 6 Old 06-01-2012, 01:10 PM Thread Starter
comanche17
1996 FSJ Cherokee
well i dont know what i did but everything works now. all i did was replace a blown bulb on the passenger rear tail light and everything is back to normal now.
thanks for the help.
post #5 of 6 Old 06-26-2012, 11:27 AM Thread Starter
comanche17
1996 FSJ Cherokee
well everything was fixed. now everything is back to the way it was when i started. this has to be a wire problem right? it wouldnt be the gauge cluster would it?
post #6 of 6 Old 07-12-2012, 05:02 PM Thread Starter
comanche17
1996 FSJ Cherokee
I finally fixed the problem. It was the wiring loom connector for the lights in the front. it was so badly corroded it practically crumbled in my hands. So i by passed it and now everything works great.
cherokee , gauge cluster , headlight , jeep , turnsignal
turn signal problem Bragi XJ Cherokee Technical Forum 0 05-23-2010 05:43 AM
1991 cherokee turn signal problem WORD9SMITH XJ Cherokee Technical Forum 0 08-21-2009 09:47 PM
turn signal problem lifted89xj XJ Cherokee Technical Forum 6 12-26-2008 11:25 AM
95 Cherokee turn signal problem Solidsyko XJ Cherokee Technical Forum 1 03-04-2008 02:18 PM
96 cherokee turn signal problem Hesher420 XJ Cherokee Technical Forum 6 12-31-2005 11:51 PM
