96 cherokee o2 sensor messing with trans? - JeepForum.com
post #1 of 3 Old 03-04-2013, 10:46 PM Thread Starter
19Cherokee96
96 xj 4.0 4x4. auto trans. recently it would rev up while driving then kick back into gear. only did it once or twice in like say a 60 mile drive. the check engine light came on threw a o2 sensor code after the converter.. well tonight while driving down the highway it kicked out of overdrive into like 3 gear, came to a stop had no power like it was stuck in 3rd. pulled over turned it off and back on and had full power. would a bad o2 cause this?
19Cherokee96 is offline
post #2 of 3 Old 03-05-2013, 07:59 AM
pokeyxj
On my 96 the forward O2 sensor went bad. It caused the engine to buck and lose power intermitently. The trans would down shift due to the engine running bad and losing vacumm. Check the codes. If it is an O2 sensor, I suggest replacing both. At least mine had 2, one on down pipe and one after the cat.
2000 XJ Limited, 4.5 Rusty's All spring lift; 265/75/16 BFG KM2's; 4.0, aw4, 242.
2001 XJ Sport, 4.5 Rusty's lift, 32x1150x15 Hankook Dynapro MT's. 4.0, aw4, 231, 8.25 rear with power trax locker.
08 f 150 2.5 lift, 33's, arb.
pokeyxj is offline
post #3 of 3 Old 03-05-2013, 06:16 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
You always should chase every code that occurs, but that symptom does NOT sound like an oxygen sensor issue to me.
You would need to determine if this is an electrical or a mechanical transmission problem if this continues. Consult the factory service manual for how to do this.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
aw4 , sensor , trans
