96 cherokee just died... - JeepForum.com
post #1 of 39 Old 12-30-2009, 07:42 PM Thread Starter
dustydoesit
1996 FSJ Cherokee
my Cherokee died half a block from my house, i have good fuel pressure, 3/4 inch spark at all cylinders, fuel injectors are working ...it cranks but wont fire at all i get a pop once in awhile but nothing more. coil,distributer,cap rotor, plugs and wires are new. new crank sensor. fuel filter is new, fuel pump is working. what else is there? besides valve timing? ignition timing is controlled by pcm and is timed right...maybe valve timing and ignition timing aren't matching? timing chain is not broken. maybe jumped time? charging system, battery, starter, alternator, and cables are all new as well. the battery is strong. i know this jeep inside out but i'm stumped... any ideas?
dustydoesit is offline
post #2 of 39 Old 12-30-2009, 07:46 PM
m_amilli
My Jeep Did The Same Thing.. I Changed All That Stuff And It Came To Be A Short In The Wire Coming Out The Tranny.. In The Middle Of Your Jeep Underneath Check To See If A Clip Or A Zip Tie Came Off Your Wires By The Tranny Maybe A Chopped Wire Like Mine
m_amilli is offline
post #3 of 39 Old 12-30-2009, 08:08 PM Thread Starter
dustydoesit
1996 FSJ Cherokee
are you talkin about the crank sensor? it's new, or maybe a ground wire? or are you talkin about the 02 sensor on the cat?
post #4 of 39 Old 12-30-2009, 08:14 PM
m_amilli
its by the cat.. i dont know much about what parts are called but def not the crank sensor.. not by the bell housing
m_amilli is offline
post #5 of 39 Old 12-30-2009, 08:15 PM
m_amilli
by the thing that spins when you drive underneath
m_amilli is offline
post #6 of 39 Old 12-30-2009, 08:21 PM Thread Starter
dustydoesit
1996 FSJ Cherokee
sounds about right to be the 02 sensor but it's only 6 months old and that would only cause erratic idle..
post #7 of 39 Old 12-30-2009, 08:29 PM
m_amilli
it connects to the middle of the tranny tho
m_amilli is offline
post #8 of 39 Old 12-30-2009, 08:43 PM Thread Starter
dustydoesit
1996 FSJ Cherokee
i'm gonna have to check that out...
post #9 of 39 Old 12-30-2009, 08:44 PM Thread Starter
dustydoesit
1996 FSJ Cherokee
not the neutral start switch?
post #10 of 39 Old 12-30-2009, 08:55 PM
m_amilli
nope it is 3 wires that come off the middle of ur tranny
m_amilli is offline
post #11 of 39 Old 12-30-2009, 09:05 PM
kzjim
Cam position sensor maybe?
"Those who hammer their guns into plows will plow for those who do not"...Thomas Jefferson
"Beware lest the Stone Age return on the gleaming wings of science." - Winston Churchill
kzjim is offline
post #12 of 39 Old 12-30-2009, 09:09 PM
m_amilli
srry if i couldn help dude.. i had the same prob
m_amilli is offline
post #13 of 39 Old 12-30-2009, 09:11 PM Thread Starter
dustydoesit
1996 FSJ Cherokee
no cam sensor on 96 cherokee. only crank and thats on top of the tranny by the flywheel.it has three wires but i changed that already ..
post #14 of 39 Old 12-30-2009, 09:22 PM
oderalxjlaredo
You're about to get sigged, my friend.
As the for OP, maybe check the connector at your computer and ensure all the wires going to it are good.
I know you said it's new, but I would also test the crank position sensor, and make sure the rotor in the distributor is properly oriented. Assuming you have an automatic, will it try to start in neutral?
That's the best I've got for now.
oderalxjlaredo is offline
post #15 of 39 Old 12-30-2009, 09:33 PM
offroadnut36
1990 XJ Cherokee
maybe a bad negative batt. terminal ground. when it pops do all the electronics go out, then come back on after a while?
offroadnut36 is offline
my cherokee died any ideas? CherokeeGT XJ Cherokee Technical Forum 12 09-09-2009 09:24 PM
cherokee ran then died jeepin71 XJ Cherokee Technical Forum 0 04-27-2008 12:23 PM
Cherokee just died jasfro XJ Cherokee Technical Forum 4 09-29-2004 02:07 AM
1998 Cherokee died VABarrister XJ Cherokee Technical Forum 20 08-25-2004 08:44 AM
My Cherokee died on me at 70mph tom from boston XJ Cherokee Technical Forum 2 09-24-2001 09:38 PM
