96 cherokee brake pressure - JeepForum.com
post #1 of 6 Old 07-30-2013, 08:25 PM Thread Starter
Unclebrixxy
Ok, all of a sudden I have hardly any brake pedal pressure. Filled up the brake fluid. When car is off brake becomes hard again. Happened out of the blue but I do kind if recall hearing a crunching sound from the rear end before it happened. Any quick, cheap or easy suggestions?
Unclebrixxy is offline
post #2 of 6 Old 07-31-2013, 10:19 AM
psychoteen101
start with the obvious and look for leaks. Known problem area is with the wheel cylinders in the drums failing. Typically it goes somewhat un noticed because a majority of fluid stay inside the drum so you cant visually see the leak without removing it.
1996 Jeep Cherokee- Project-- Rusty's 8in long arm, SYE kit, Teraflex driveshaft, Cragar soft 8's 15x10 with 33x12.5 Firestone Destination MT's, Eaton Tru Trac in the front
psychoteen101 is offline
post #3 of 6 Old 08-01-2013, 09:30 AM Thread Starter
Unclebrixxy
After refilling the brake fluid and pumping the brakes a thousand times the pressure came back to almost normal.
post #4 of 6 Old 08-05-2013, 04:09 PM
psychoteen101
The fluid must have gone somewhere. Check for external leaks. Could possibly have leaked in to the brake booster. If that's the case, you might not see any leaks
post #5 of 6 Old 08-05-2013, 10:55 PM
Arkansasboy
It may not be a bad idea for you to check the master cylinder to see if the seals around the pistons are bad that could cause the low pressure in the peddle also
Arkansasboy is offline
post #6 of 6 Old 08-26-2013, 05:43 AM Thread Starter
Unclebrixxy
Bad brake cylinder on rear passenger side
