96 Cherokee 4x4, replacing rear wheel bearings - JeepForum.com
post #1 of 6 Old 06-21-2007, 12:34 PM Thread Starter
md95
My name is Matt, and this is my first post here! I just bought a 96 Classic with 220k on it, and it runs/drives really good. I need to replace the rear wheel bearings on it, as they howl/groan going down the road. They feel rough as you spin the hub, so i know they need replaced. I believe the rear axle is a Dana 35. My question is what is the best way to do these? I pretty much have all the special tools needed(hoist, pullers, shop press, ect). From what i've gathered, the bearings are pressed on? If there is a link to a how-to, or if someone can give me some info on the process, i'd greatly appreciate it! Thanks
md95 is offline
post #2 of 6 Old 06-21-2007, 01:22 PM
severous01
severous01's Avatar
they're not pressed on. they're pressed in. not really though...
all you gotta do is pull the axles, slide-hammer the bearings and seals out. that's it...
if the new bearings are loose, wrap the race with foil and then hammer them it.
severous01 is offline
post #3 of 6 Old 06-21-2007, 02:34 PM Thread Starter
md95
Thanks for the info. In order to remove the axles, do you have to remove the diff cover, then i assume there are C clips on each axle end going into the differential? Thanks again!
md95 is offline
post #4 of 6 Old 06-21-2007, 03:58 PM
AZ Jeff
2014 JK Wrangler
Yes, pull the diff. cover and remove the c-clips to take out the axle shafts.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #5 of 6 Old 06-22-2007, 10:12 AM Thread Starter
md95
One more queston..Do you need to remove the backing plate to get the bearings out? Or can you remove the bearing seal, then the bearing using a slidehammer puller with the backing plate still on the axle housing? Also, what's the probability of the axle bearing surface being chewed/bad? I'd like to get this done all in one shot, without having to wait to order new parts..Thanks for the help guys!
md95 is offline
post #6 of 6 Old 06-22-2007, 10:17 AM
88XJ_WI
1988 XJ Cherokee
the backing plate does not need to come off. It would depend on how bad your bearing are if it's chewed up. I'd think it would need to be pretty like the axle shaft is moving around. I'm pretty sure that you can get some offset bearings for it if it is that bad.
88XJ Laredo
4.0 L, AW4 190,000 miles
96 Grand Cherokee 4.0 145,000 miles
88XJ_WI is offline
rear end or wheel bearings going bad? 96xjbuilder XJ Cherokee Technical Forum 5 05-04-2008 03:36 PM
Replacing front wheel bearings... ??s kurtw XJ Cherokee Technical Forum 13 11-26-2006 04:12 PM
rear wheel bearings sik95xj XJ Cherokee Technical Forum 4 07-25-2006 06:18 PM
rear wheel bearings? BIGNUTT XJ Cherokee Technical Forum 2 04-26-2006 04:53 PM
rear wheel bearings? CherokeeCountry XJ Cherokee Technical Forum 9 10-03-2005 11:19 PM
