'96 4.0L XJ has mediocre braking - JeepForum.com
post #1 of 4 Old 07-01-2010, 10:28 PM Thread Starter
Svenlylethor
So my XJ has about 221,000 miles and the brakes work but not very well. I feel like I have to brake really hard to get it to stop, especially when it's sudden. I used to have a Ford Ranger and an F-150 (both manual) and they had great braking plus whenever I borrow people's cars, I slam the breaks the first few times just because they work so much better than my jeep's.
I think the brakes are still in good condition and still have lots of wear left on them but my question is if there is anything to change the performance. Could I put in an upgrade master cylinder or something?
[]IIIIIII[]
Svenlylethor is offline
post #2 of 4 Old 07-02-2010, 02:41 PM
scott_jeep
Well even with a perfectly working system XJ braking leaves much to be desired. My finance has a 2010 Ford and I do the same thing with the pedal, whenever I'm driving and that first stop comes everyone gets whiplash
But you're sure everything is in working order? Checked master cylinder, lines, calipers, rotors, pads, fluid, etc?
I just replaced the pads on my 96' and found that there was a small leak from the piston on one caliper. Replaced both, bleed it well and went on my way. My brakes feel a million times better now. I didn't even realize how bad they were before.
So first I'd check that there are no leaks or other problems and then if it still seems bad maybe upgrade the rear drums to discs?
scott_jeep is offline
post #3 of 4 Old 07-02-2010, 02:48 PM
DirtyViking
1995 XJ Cherokee
Most times the rear drums end up being quite bad, and the only way to really tell is to pull the drums off and inspect their wear surfaces and the brake pads themselves. If those aren't working, you're only stopping the vehicle with the front brakes, and of course that'll feel horrible.
Originally Posted by Dcomf
As far as chicken coops go you'll only need 2 doors, if you had four then it would be a chicken sedan. :D
Originally Posted by Rob99
You can't post a thread in GD and expect only responses that you like. People have opinions. If you don't want to hear opinions, go have a conversation with yourself in the mirror.
After allegedly failing a sobriety test, Donald Duck was taken into custody.
Do evil every day. You may not change the world, but you'll have fun.
Halmotors on the PS3 network
DirtyViking is offline
post #4 of 4 Old 07-03-2010, 12:24 AM Thread Starter
Svenlylethor
My brake fluid is always where it should be plus the brake has never felt spongey before... so I don't think it's the fluid.
You can really upgrade the rear drums to discs? I'll have to look that one up. I think I've heard of people upgrading their XJs with the master cylinder from a WJ.
[]IIIIIII[]
brakes , performance
braking sportbikeridr XJ Cherokee Technical Forum 18 06-20-2010 02:54 PM
braking axles brewco XJ Cherokee Technical Forum 10 04-04-2006 04:52 AM
Engine knocking, cutting out, mediocre pick-up homerscj7 XJ Cherokee Technical Forum 1 11-19-2004 11:54 AM
Better braking XJeepness XJ Cherokee Technical Forum 2 07-10-2004 11:37 PM
