96 4.0 serpentine belt - JeepForum.com
post #1 of 3 Old 07-09-2012, 10:26 AM Thread Starter
noshine84
My belt started whining the other day. So I got to looking around and the belt is rubbing the timing pointer. I've search and it looks like my belt tensioner is in the wrong spot? All the pictures I've seen looks different than mine. Anybody ever seen a AC equipped 4.0 with the belt tensioner below the power steering pump and not by the compresser?
noshine84 is offline
post #2 of 3 Old 02-25-2014, 09:40 AM
Tru2Chevy
Tru2Chevy's Avatar
1992 XJ Cherokee
I know this is quite old, but I'm replying just so others will get the correct info if/when they come across this thread in a search.
The belt tensioner on the 96-01 4.0 XJs is the idler pulley below the power steering pump. Just loosen the bolt that holds that pulley and then turn the adjustment bolt to tighten / loosen the belt.
The 87-95 XJs used the power steering pump as the tensioner, so you have to loosen several bolts on the pump and then turn the adjustment bolt under the power steering reservoir to tighten / loosen the belt.
No XJs came with the spring loaded belt tensioner that many people are used to seeing.
- Justin
1992 Cherokee Laredo - mostly stock, DD. 300k miles and counting
2004 Grand Cherokee Laredo - 4.7, bone stock - Wife's DD
Tru2Chevy is offline
post #3 of 3 Old 02-25-2014, 10:13 AM
00XJMikey
- Justin
And now I can de-slop my belt. Thanks
00XJMikey is offline
Serpentine belt squeal, new belt & tensioned V-R XJ Cherokee Technical Forum 2 11-27-2011 08:46 AM
Serpentine BElt armystrong2121 XJ Cherokee Technical Forum 5 04-06-2010 09:01 PM
92 serpentine belt HELP!!! scoot08 XJ Cherokee Technical Forum 4 12-04-2008 06:56 AM
serpentine belt...? bezerk XJ Cherokee Technical Forum 1 10-16-2006 04:45 AM
Serpentine Belt Help XJChris98 XJ Cherokee Technical Forum 6 10-01-2006 10:05 AM
