95 XJ Transmission problem, late shifts, replaced TPS & still problems - JeepForum.com
post #1 of 2 Old 08-03-2010, 10:43 PM Thread Starter
RidgeRunnersXJ
1995 XJ Cherokee
Hey everyone,
first time post but longtime forum follower wishing I had the time & money to do a lot of the builds/mods here on the site, anyway my 1995 Jeep Cherokee Sport, 4WD 4.0L 130,xxx miles, stock tires, stock axles, pretty much everything is stock. It seems that my transmission shift points are off (late) and the shifts are heavy/clunky/generally off, the jeep struggles to accelerate beyond 25 mph if the throttle is held constant and then again at 35 mph, it used to do 65-70 at 2100 rpm but now does 55 at 2100 rpm. It used to accelerate and shift up the gears with light constant throttle application but not anymore. Just replaced the TPS and still having problems, the transmission fluid levels are fine, color/smell is fine. While driving there are no grinding noises or gear whine. The problem used to be intermittent but is now becoming constant. Hoping to figure this out before having to take it to the dealership or aamco because a major problem might be curtains for the XJ
any comments/ideas/thoughts help,
thanks
RidgeRunnersXJ is offline
post #2 of 2 Old 12-26-2010, 11:34 AM
alexk243
1994 XJ Cherokee
Try a transmission cleaner like Lucas. I know some people disagree but pulling the pan and cleaning the filter and fluid in the trans as well as the magnits in the pan worked well and my 184000 mile Cherokee shifts real smooth now.
We did however decide not to do it on my dads Yukon since we didnnot want to break up parts in the trans
1994 Jeep Cherokee 4.0L
alexk243 is offline
cherokee , problem , tps , transmission , xj
replaced transmission, bad TPS causing shift problems? C-Mil XJ Cherokee Technical Forum 11 05-31-2015 11:22 AM
Transmission shifts to OD at 35 mph? scottyknows50 XJ Cherokee Technical Forum 29 12-10-2009 04:33 PM
transmission shifts late Norton21 XJ Cherokee Technical Forum 6 02-08-2009 03:17 PM
Transmission Shifts hard in 4x4. RamboPants XJ Cherokee Technical Forum 0 10-22-2008 04:28 PM
Stumbles and Shifts late!!! on my DD collkid XJ Cherokee Technical Forum 2 08-28-2007 07:13 PM
