95 XJ no start - JeepForum.com
post #1 of 4 Old 09-23-2011, 09:39 AM Thread Starter
Cedfelix
1995 XJ Cherokee
95 XJ no start
I've poured over the forums now I'm a bit stuck.
Two days ago I the Jeep ('95 XJ 4lt 4WD 160k) was having trouble starting. It would start and crank over, then immediately die. After 3 rounds of this, the jeep started up and ran fine with no other problems for another 3 starts. Yesterday morning same issue as previous morning. I stop to grab food after about an hour of idling in traffic and the jeep will start and crank over, but will not keep running. The gauges look normal when starting.
Replaced the fuel filter, no change.
Replaced the fuel pump and made sure there was enough fuel in the tank, no change.
Swapped fuel pump relay for another, same type relay, no change.
No visible fuel leaks.
I don't have a fuel pressure gauge, but there is a good amount of fuel coming out when I press on the check valve.
When I turn the ignition on, the fuel pump runs for a half sec, then shuts off. If I jump the relay, the fuel pump runs for 3-5 secs.
I'm off to check the CPS with a volt meter now.
The battery terminals are super clean, also new cable terminal ends were just installed 2 weeks ago.
Any thoughts? Thanks in advance.
Cedfelix is offline
post #2 of 4 Old 09-23-2011, 09:58 AM
The_Blacksmith
1993 XJ Cherokee
might not be a fuel delivery issue, could be weak spark.
Thanks Chris!
The_Blacksmith is offline
post #3 of 4 Old 09-23-2011, 10:00 AM Thread Starter
Cedfelix
1995 XJ Cherokee
What would be the next step? Replace the spark plugs?
Cedfelix is offline
post #4 of 4 Old 09-24-2011, 07:18 AM Thread Starter
Cedfelix
1995 XJ Cherokee
Fixed!
We found if you started the Jeep but didn't turn the key back, it would still run. We then replace the ignition switch and it runs like a champ.
Cedfelix is offline
1998 XJ Won't start on 1st try, fires right up on 2nd attempt / slow start spenceuiuc XJ Cherokee Technical Forum 18 08-06-2012 07:26 AM
No start......Replaced the Crank Sensor and still no start, Whats UP? batilzown XJ Cherokee Technical Forum 3 02-17-2010 01:50 PM
electric start prob. jeep wont start blackl4life XJ Cherokee Technical Forum 1 08-21-2009 09:56 AM
interesting hard start/no start/dead battery problem TXjeep97 XJ Cherokee Technical Forum 4 02-18-2008 09:18 PM
Eh.. start? no start? roll the dice? jiggle the cable? UnderDog! XJ Cherokee Technical Forum 6 05-25-2006 10:14 AM
